Adding tv in 2020 is going into sub category
Hi, when i add tv series to my plex it adds it into a wierd folder in my tv, all tv is labeled correctly in my computer its only once i add it too plex that it goes into this folder, i can not add more than 1 tv series if i want to “fix match” if i add more than 1 i can not fix the match without the other tv series being labeled wrong, anyine else had this problem
Not quite sure what problem you experience… it looks like the photo is showing that tv show overview ok.
How exactly did you organize your show(s) and which folder within that path/structure is linked to the Plex library?
PS: You don’t need to take a photograph next time, you can just capture your screen which is much less work.
To capture your entire screen and automatically save the screenshot , tap the Windows key + Print Screen key. Your screen will briefly go dim to indicate that you’ve just taken a screenshot , and the screenshot will be saved to the Pictures > Screenshots folder.
Also, Alt + Print Screen will take just a screenshot of the app (so we only see the Plex app).
I’d be more interested in naming and structuring and file paths back to the root - than a photo of a messed up show.
The cure can usually be hammered out when you have the former - and a photo of a messed up show doesn’t do anything to get to the problem.
