[adult] Kink.com metadata agent
BelgianDom: The scraper does not reliably retrieve Kink.com data from shoots older than the ones that appear on /channel/{self.site}/latest so it is difficult to test if the 4-digit ID (and 3-digit ones exist as well) regex works.
I had to change mine to shootIds = re.findall(r’\d*((\d*)\D*’, filename) to match the naming convention I have of YYYY-MM-DD - Actors Here (ShootID).mkv but I have tried it with the default regex and renamed a few files to test (with limited success).
There is also a conflict if two shoots from the same site are released on the same day. See 41315 and 41322 as an example. Both will always show as the same, presumably because a date hit is a ‘100%’ match.
I noticed that the shootIds I posted got formatted into being incorrect, before I get called out on that.
I just tested the Intersec scanning, and it won’t always try the correct URL if there are multiple actors in the URL itself. For instance: Requesting ‘http://www.sexuallybroken.com/sexual/bondage/trailer.php?y=2014&p=03_28odelacroix
…when the correct URL is /trailer.php?y=2014&p=03_28odelacroix_ehaize3
Not sure where to start on fixing that. I am by no means good at this.
I’ve just merged the changes from yh on github. Haven’t tested them, TBH, but I assume they’re better than whatever we had before :slight_smile:
Nice work. Most of the videos I find are titled such that the shoot number is at the end in parentheses though. So I end up having to manually match most.
This isn’t pulling any information from me after manually matching, are there any updates?
First off. Thank you for this script! I really appreciate it. Second, is there a way to make it read the shoot ID from the end of the file name?
Is there anyway to save this on my hard disk? Instead of it being on Plex?
thanks!
It’s working great for me, with the exception of just one thing.
It’s not pulling the release date- I just get 1900-01-01 as a placeholder in the file, and nothing showing for release date.
I can’t seem to find any way of fixing this.
On what site?
It was on all the Kink sites.
But since the recent new version with the changes for the field alterations on Kink, it’s been working very nicely again- thanks.
Actually, the non-core Kink sites hosted on Kink.com aren’t matching despite having the right shoot ID- Bleu, Wasteland, F&B etc.
They come up as matched in my library but don’t fill out any of the shoot details, actors, studio, etc.
Anyone got any ideas?
