@Plex4Fun should not be too hard to fix since the site name has changed and there must be another thing which is not working 100% correctly. Not a coder so I cannot fix it.
I tried changing the URL and got to this point trying to match TheWhiteboxxx. See Log if anybody has a clue what could be the fix… happy to trygithub.txt (819 Bytes)
I’m trying to add provider for dogfartnetwork.com.
Search function seems to work fine, I tried " Dogfart - Tina Kay", and i had several results. But when i choose one of them, the update function is not launched…
Please, can someone help me and tell me what’s wrong in my code and why i can’t update metadata ?
TY
Hello and thanks for these.
I downloaded the last version of it copied the PhoenixAdult.bundle into plexmediaserver\Library\Application Support\Plex Media Server\Plug-ins and restarted my PlexServer. But the Agent is only in the Movie Selection not in the TV Shows. What i’ve did wrong?
I’m a little confused. Can someone briefly explain exactly what this channel/plugin does please? Does it give us access to watch the movies/scenes? Or helps labeling them? ??
Whats the best way to go about this if my stuff was previously matched with data18 and then anything that didn’t have a match i’ve manually added posters and descriptions etc. I don’t want to change anything that currently i have matched or manually done. only new content which has built up since data18 went down
You can easily set your existing data18 library to this agent like i do. All the new stuff will match and your old stuff stays at it is.
For those who want to rename a large amount of stuff i recommend a little tool called advanced renamer. Saved me so much time to add sitenames or rename folder structure.
I’m a new user. I have Plex installed on Synology NAS and have uploaded adult movies and videos to the NAS. In the libraries I originally had adult movies in a “movie” library-type folder and videos in a “other videos” library-type folder. I had website folders and subfolders for the different areas. The file naming convention was “title - actor” within the website subfolders. It appears the best way to organize the adult scene videos is to move all the titles into one folder and rename all the titles with “site - title” or “site - actor” if no title is available in one folder and let the agent parse the subfolders as collections. I have software to quickly rename groups and can add the site name and remove the actor information from my current titles. What is the best way to organize the files to support the agent. Also, if I remove the actors from the title and the file isn’t found, how can I preserve the actor information I have manually collected. Thanks in advance.
