[adult] PhoenixAdult - Multisite Adult Metadata Agent - Development
Anyone else having trouble with this plugin working, none of the data18.com work for me, the regular one doesn’t show any cast pics & this one doesn’t find the film that i know is there, I renamed the file the right way too.
Hey guys,
I’m way more active on GitHub than I am on here. I have a thread setup there specifically for requesting new sites (https://github.com/PAhelper/PhoenixAdult.bundle/issues/1) and I do a lot more bugfixing to issues reported there as well.
A few quick replies scrolling back through this thread:
@thecat18 If you’re having trouble with the PhoenixAdult agent, head over to Github and create an issue, I’ll try to get it resolved.
@justmultiplex I’ve added your sites to my request thread. I don’t think your fork automatically gets updated, but if you add stuff to your fork, you can always send a Pull request and I’ll integrate your changes manually if I have to. If you just want to use the agent, you shouldn’t need to fork it.
@jaysifer My fork includes that functionality, and Connie Carter is already programmed as one of the name substitutions. Download the PAhelper fork and you should be good. Let me know if you find other aliases that need to be added…
@Hoppebolden I may have broken something, or the site may have changed. Please make an issue on Github and we’ll get it fixed up.
@sticks32 PornPros and Mofos are supported in the PAhelper fork, Nubiles is on the short list to get added soon… Though I should say PornPros doesn’t work on Linux-based OS because of a library dependency within Plex itself (we think, still looking into it). Works fine on Windows though.
@thecat18 This agent has nothing to do with the data18 agent. the data18 agent receives data from www.data18/movies. The PhoenixAdult agent receive data from the adult website with the origin of the content, mostly for scene videos. It is not made for full movies, but there are few exceptions.
If want to match a film you know its on data18.com/movies u can still use the data18 agent. The missing cast pics is a problem with the agent not yours.
Thanks for clearing that up I did notice the few exceptions with hot bodies 1 the one I tried. Well the data18.com/ content script is just like the Phoenix but Phoenix has more sites. The cast pics for data18 that don’t show up will when using the program jav scraper.
This is great work, thank you!
I’m having trouble to organize my blacked/raw/tushy/vixen folders, phoenix still work for those sites ? Because every scene i try to search for the details, i get nothing in return. ADE agent works flawlessly for my Private/Dorcel movies, problem is the scenes from pay-sites
I Made it Work for almost all my videos so far, but Dorcel Club don’t work, any tips on how can i search, i tried [Site] - [VideoName] or [ActressName] - [Date] - [Site]
tushy.com seems to be broken. Cant pull any metadata.
Whoever is doing the blacked.com (and possibly tushy and vixen) scraper… it isn’t escaping the tags correctly. Quotes are being included in the string for the tag. That is to say that rather than the tag being Reverse Cowgirl, it ends up being "Reverse Cowgirl". This is particularly troubling, because it appears in some cases the end quote gets truncated and the tag ends up being just one word that is non-escaped with either a beginning or ending quote (e.g. "Reverse and Cowgirl")
Any chance to include TushyRaw ?
I was able to find my video from Naughty America, but hardly any metadata shows up. Just the title and nothing else.
Can somebody help. I get no results with the plugin. I try to search over actor or scene name but really 0 match. What im doing wrong. I have a Synology NAS
Hey guys, Just a reminder that the original github repo is effectively abandoned. We all hope Phoenix is alright but the PAhelper fork is where all the activity, support and updates are.
I’ve installed the plugin, set the scanner to Plex video, and selected Phoenix as agent, but no results. It randomly worked yesterday for my Tushy and Blacked content but not anymore after re-adding the same folder to test the agent. Any ideas for troubleshooting? Could a VPN cause problems here? Really want to get this working as it was AWESOME when it worked
Just so I’m not sitting here pulling what little hair I’ve got left out could someone explain to me how to name my Brazzers files so that they get matched automatically? Or can’t I and will I have to manually match them?
@unabatedshagie you can find the naming for each supported site here: PhoenixAdult.bundle/docs/ sitelist.md
For Brazzers Network
Matching type: Limited - Title only
This means you have to name them like Brazzers or with the SiteName (e.g BrazzersExxtra / DoctorAdventures …) + Title (title must match the one on brazzers.com)
Example: BrazzersExxtra - Party for One
Hi , great work with the bundle. Mostly seems to work well, but stuck trying to either automatically or manually match to Evil Angel. Any tips would be welcome.
Is anyone else having issues matching files? PheonixAdult Agent cannot match any of my files. This includes files I had previously matched before.
I’m having the same problems. Sites that worked before is not working anymore. Hopefully it get’s fixed soon. :crossed_fingers:
Just discovered this and trying to get it to work. I have it in the same plug-ins folder as my other plug-ins, renamed the folder to end in .bundle, and yet it doesn’t appear in available agents. Either I’m overlooking something obvious or missing something vague.
Plex version 1.18.3.2129, FreeNAS version 11.2-U7
