Advanced Filters (Dynamic playlist problem)
I’m using advanced filters to get dynamic playlists. Generally, if I like a song from an artist enough and it gets approved for “Perfect for my commute” I rate it 4 or 5 stars. The filter is for example:
Artist Title is Chefdenker
Track Rating is greater than 3
And I name it something like Chefdenker FUN. This works perfectly. Rating a new song and it’s instantly in rotation.
What I’m looking to do is to create a playlist which contains the songs from a band rated less then 4 or completely unrated. If I didn’t mess up it looks like a filter of Track Rating less than 4 doesn’t include unrated tracks. Is this not possible without rating every song in my library at least one star?
Maybe someone has a soulution? If not I’d like to propose to count unrated songs as 0 stars or the ability to add “not meber of xyz filter” as option (Spoiled from jamf smart groups :-D)
Thanks a lot
Add a separate filter for unrated…
Match any…
Track rating - is lower than - 4 Stars
Track rating - is unrated
Thanks a lot for the reply.
My problem was that the rule group didn’t save the first couple of times I tried. Don’t know why but now it saved successfully .
It’s working now exactly like I want to
