Advanced Tab Under "Edit Library" is Disabled/Unavailable
Server Version#: 1.16.3.1433
Player Version#: n/a
I am trying to change the agent for one of my libraries but the “Advanced” tab under the Edit Library screen is greyed out and I cannot access the settings. What would cause this behavior and how can I access my settings?
No player version.
Are you using the built-in local host(http://127.0.0.1:32400/web/index.html) or are you using the hosted site(https://app.plex.tv/desktop)?
I’m having the same issue and can’t seem to find an answer. Did you figure out what was going on?
Until this is resolved, you can access the advanced settings for your libraries by navigating to Settings -> Libraries, and then selecting Edit for the library of interest; “Advanced” is still accessible there.
It is fixed in the current server version 1.18.0.1846, if not available download it from Plex.tv
Well it is for me on Mojave 10.14.6
Not fixed for me in 1.18.3.2156. Also in Mojave.
This is what I find.
Occasionally, when I try to edit a library (from the 3 dots/Manage Library/Edit) the General tab is available, the Add Folders tab shows no folders specified (obviously wrong) and Advanced is disabled and unavailable.
If I then go to Settings and edit that library, everything is available and correct.
Is this actually some sort of bug or is it intentional and if so, why? Can anyone explain this?
Try making a new Library
I have observed that if there are changes in the library folders, and the folder has not been scanned yet, the advanced option is grayed out. If you then choose ‘scan library for changes’ the advanced option becomes available again. I do not know if this is by design or not.
In addition to what others have suggested I’ve found that, when I’ve experienced the problem, the advanced settings are always available if you edit the library from Settings → (Manage) → Libraries:
I still can’t get collections to move away from library. Have tried the advanced option.
This is very off topic but i will send you a message explaining.
