After Unraid USB restore Plex no longer starts. Execution Error. Server Error
Server Version#: Up to date [plexinc/pms-docker] as of March 13th
I had to restore my Unraid USB drive, as my original USB drive died.
Once the drive was restored, Plex would no longer start up. When trying to startup the Docker, it comes up with an Execution Error. Server Error window.
I have tried restarted the Unraid Server, but did not fix. I have other Dockers that are working.
Server logs might contain a hint.
Did your old USB drive contain both media and the server data directory (database etc), or just the media?
Tried to upload logs but failed.
Looking at the logs, there is nothing newer then 1 month ago, and that would be before the USB drive was replaced.
USB is just to boot the Unraid OS. The USB did NOT have the media. Do not believe the USB had the server data either. Where I found the logs, is located on an SSD in the sever. Media is on some HDDs.
Seems to be that my DVR tuner stopped being recognized.
Removing the Extra Parameter for the tuner, and Plex started right up.
