Plex Server not accessible from any device after a power outage
Server Version#: 6.12.1
Player Version#: Latest in Unraid
I had a power outage longer than my battery backup could keep the server up and when I brought it all back on line, the Plex Docker doesn’t work (Unraid). I took the opportunity to upgrade Unraid to see if it would help, it did not.
The Plex docker says its started and running, and in Windows I can see my tower, all the folders and files are there, the network is working fine.
I just can’t reach that server from any device, including this laptop. Normally when I logged into the Unraid GUI, if I clicked the Plex icon next to my server the top option would be WebUI and I could launch the app in my browser from there, this was especially helpful if the IP changed during an outage as I could update my bookmarks.
Now that spot says console, and just brings up a console window with number sign.
I have no idea where to go from here, all TV’s, phones, laptops are acting like the server isn’t running, but Unraid thinks it is, and I know the network is fine.
Thoughts?
Stop Plex Media Server.
Navigate to the Plex Data Folder.
Zip the Logs directory and upload to the thread.
Someone knowledgeable with running Plex on Unraid/Docker can hopefully assist.
tower-diagnostics-20230622-2328.zip (98.4 KB)
Those appear to be your system logs, not your Plex logs
I don’t know Unraid or docker but this might help
I did see one error in those logs
Jun 22 21:37:04 Tower ntpd[1185]: kernel reports TIME_ERROR: 0x41: Clock Unsynchronized
No idea if that has anything to do with your problem, I’m just letting you know
