AirPlay audio receiver in RasPlex 0.7.1?
I’m using RasPlex successfully for all my Plex media. But, the current Plex support for iTunes playlists is not-quite-good enough for my daily use, so I would like to use the AirPlay audio capabilities to stream from my iPhone (where my complex playlists aren’t hacked to shreds).
But I cannot find a way to access RasPlex once I’ve enabled “Allow PHT to receive AirPlay content” in Settings.
Is there anything else I have to do to get it running, and visible on my iPhone (iOS 8.4.1), like other AirPlay receivers? Are there logs I can review to see what might be happening?
I have the same problem with Rasplex 0.6 and 0.7. I can’t get Airplay working at all on 0.7, receiving a file not found error or no Airplay target at all.
I’ve recently downgraded to 0.5.1 and Airplay works perfectly again. So it looks like something was broken after 0.5.1.
Chris
