Airplay only streams audio and no video
Hi, and thank you for this awesome product.
I have a Raspberry pi 512Mb, and I installed on it rasplex. I installed Plex Media Server on my computer on the same local area network. Everything works except Airplay for videos. When I launch a video from my iPad and select Airplay to rasplex, it only streams the audio but no video.
I had previously installed XBMC and and raspbmc, and Airplay with video and audio was working properly.
If it can helps, I configured my router first with TCP, and now in UDP mode for the Plex Media Server : same result, no video.
Could you help me to make my videos Airplay working ?
Been happening to me and a few others ever since ios7 update
Interesting, I run iOS 7 on my iPad and iPhone... any solution ?
I had this issue with 3.0 of rasplex. But the update to 3.1 seemed to fix it for me. But I rarely stream content. I am also running iOS7
Unfortunately, I have this problem on iOS 7.0.2, with Rasplex 3.1. Maybe the only solution is to wait for a fix ?
I've done some test and it seems that wireless performance is worse with 0.3.1 than with previous versions. I wired up my Pi yesterday to do some further tests and after that I managed to airplay just fine from my iPad running iOS 7.02. I don't overclock and it seems the limit for my setup is a height of 720 i.e 720p.
Here is a french article about a similar problem for a different hardware, which was solved by firmware's update.
http://www.universfreebox.com/article/22429/iOS7-rend-impossible-l-envoi-d-une-video-sur-le-Airplay-de-la-Freebox-Revolution
Maybe the same could be done for Rasplex ?
Im running raspbmc and I have this issue times to times. It varies though. Sometimes youtube, vimeo doesn't allow it. Sometimes it's because of ios7.
Take a look at the icon on your iphone or ipad. If you select airplay and you see the rasplex device has a speaker icon next to it then it's not going to show any videos, only sound. If it has a monitor icon than you'll get video. Sometimes turn off and on my wi-fi on my phone fixes it temporarily :D
Weird, I know.
Hi Fabien,
Thanks for the reply but I'm afraid it's not helping.
This was a firmware update for the Freebox. I do not have a Freebox, but a BBox (Bouygues Telecom).
In any case, my rasplex software is up to date (the server also).
Weird, I know.
Yes, it's a weird problem that occurs not only on Plex environment.
It seemed like iOS7 changed something for Airplay, that need to be re-implemented / re-coded... hope it will be soon for Plex services.
Thanks for the double tips, I'll try them : icon, and turn-off/turn-on the wi-fi, I will try...
Hi Fabien,
IOS7 has changed airplay, given the airplay code comes from XMBC it needs to be updated there, last i checked (which was a week or so ago) they were not in any great rush to fix it.
It is being reported that iOS 7.0.4 fixes this.
https://github.com/xbmc/xbmc/pull/3789
Hey Plex Ninja, thanks for information.
I tried again today, and it still does not work with iPhone 4S running iOS 7.0.4.
Still waiting and hoping...
Hi Ninja,
Actually I have seen quite a lot of activity from Memphiz on this over the last few weeks, they have three test builds they are asking for help with.
I also question if this is wholly a XBMC issue?
The November builds of XBMC (raspbmc) are glitched but are recognized by Airplay, sometimes they confuse audio and video capabilities. After a few attempts you can generally connect correctly though.
This is NOT the case with plex, which does not recognize any XBMC device AT ALL.
I have also  found this with numerous other IOS based players. In that they work, but may be glitched.
So this seems to be a plex issue, in that it seems wholly intollerant, unlike the native, and other app based players.
Are you aware of this?
Given I suspect a large number of your customers on IOS I would suggest this is looked  at.
(I for example am questioning my plex pass, as currently it is pointless for me without the IOS playback :(   )
https://github.com/RasPlex/RasPlex/wiki/How-to-report-a-bug
Hi Ninja,
This is a free, open source project, It has nothing to do with your plex pass. We are 3rd party, not affiliated with plex.
Hmm ok apologies wrong forum then.
Sent from my iPhone using Tapatalk
