Album Art positioning and EQ
I am very grateful for plexamp, I think you did a great job with it. There are two things that I think can be improved.
  1. Album Art positioning in “now playing”, why is it so high? Can we have it more to the center and maybe have the name of the album on top? Or have a option to change layouts? That would be great!
  2. Instead of changing parameters in predefined zones 31,62,125,250 etc. can we click on them and change them to what we like? Also drop down menu with saved profiles would be great too.
Thanks!
just wanted to make sure you knew that you could have separate EQ profiles per device/output.
Thanks for the response, I use plexamp a lot on the go with a bluetooth DAC (btr5), to which I connect different headphones, with that I do not see how I am able to have multiple profiles, probably as it acts as one device. Also if I connect different headphones to the same DAC/AMP would it not be counted as one device? Therefore I would have to change the settings again. But if I would have the dropdown option I can easily select for example HD800s profile no matter the device its connected to. But what you wrote is good to know.
