All apps except Trailers works
Brief summary of my trials and tribulations (5 hrs worth):
  • Fresh install on Windows 8.1, 64 bit
  • Ran fine on Windows 7 same machine
  • When launching trailers app, aTV instantly says Trailers unavailable.
  • Other apps load just fine
  • Firewall is turned OFF on router and Windows
  • Regenerated certificates, removed profile and followed the guide to a TEE at least 10 times now
  • Tried 3 different versions of PMS (see below)
  • Checked permissions to files/folders
  • Restored aTV to factory, updated to latest firmware
  • Tried Python 2.7.9 at first, then 2.7.6 last few tries
The template:
  • AppleTV3,2 (A1469), Software 7.0.2 (6915)
  • The DNS server set on the ATV: 192.168.0.8
  • The local IP address of the device that PlexConnect is installed on: 192.168.0.8
  • The device and operating system (including version number) that PlexConnect is installed on: Windows 8.1 laptop
  • The device and operating system (including version number) that the Plex media server (PMS) is installed on: Windows 8.1 laptop
  • The Plex media server (PMS) version number you are running: Tried 3 different PMS (0.9.11.7)  (0.9.11.4)  (0.9.8.18)
  • The local IP address of the device that the Plex media server (PMS) is installed on: 198.168.0.8
  • The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any non-standard setup e.g. Plexify or a fork. Plexconnect downloaded from GitHub 12/29/2014 5:30pm
  • The contents of your 'Settings.cfg' file (this is created at first clean shutdown of PlexConnect, using CTR+c)
[PlexConnect]
enable_plexgdm = True
ip_pms = 192.168.178.10
port_pms = 32400
enable_dnsserver = True
port_dnsserver = 53
ip_dnsmaster = 8.8.8.8
prevent_atv_update = True
enable_plexconnect_autodetect = True
ip_plexconnect = 0.0.0.0
hosttointercept = trailers.apple.com
port_webserver = 80
enable_webserver_ssl = True
port_ssl = 443
certfile = ./assets/certificates/trailers.pem
loglevel = Normal
logpath = .
  • detailed description of the issue (the clearer you can make this the better): All apps work except for Trailers app, immediate unavailable and no change in the Plexconnect window (sometimes) when trying to launch Trailers
  • Ensure you post your 'PlexConnect.log' file to pastebin and post the link: http://pastebin.com/nYymXwkL
For the log file, I opened the ABCnews app (line 30) to show it working correctly, and then tried opening Trailers (line 50). The trailers app took a few tries until it showed in the log, but for each try the outcome was the same - an instant 'unavailable' error.
Thanks in advance for any help that can be provided. I have a feeling it is something with the certificates but I've tried it so many times (redownloading all files and removing profiles) I am stumped.
Edit: I also added the cert to Trusted Certificates in windows.
Firewall, antivirus, vmware/virtualbox, internet sharing, recent network additions/removals (new router/modem/gateway)?
With windows even if you have disabled the firewall it has been found you need the entries and windows still blocks.
I seemed to have solved the Trailers Unavailable problem by going to the properties dialog box of all *.py files in the Plexconnect directory and clicking 'unblock' since it said 'file is from another computer and may be blocked for safety.'  I had tried this on a previous install without luck but for some reason it did the trick this time. I also disconnected the Microsoft sign in and reverted to a local account login, but that was before I unblocked and didn't seem to make a difference at the time.
So now, at least the trailers app is working, but it is EXTREMELY slow. It says 'Accessing Trailers' for about 3 minutes any time I try to navigate anywhere in the gui. I didn't have this problem on the previous setup. I updated PMS to the newest version with the same result. I am still running python 2.7.6.
I am not getting any bottlenecking at the wireless card of the laptop since I have tested at 8 MB/s down and 1 MB/s up.
I have seen these erros in my log now as well:
Traceback (most recent call last):
  File "C:\Python27\lib\SocketServer.py", line 593, in process_request_thread
    self.finish_request(request, client_address)
  File "C:\Python27\lib\SocketServer.py", line 334, in finish_request
    self.RequestHandlerClass(request, client_address, self)
  File "C:\Python27\lib\SocketServer.py", line 651, in __init__
    self.finish()
  File "C:\Python27\lib\SocketServer.py", line 710, in finish
    self.wfile.close()
  File "C:\Python27\lib\socket.py", line 279, in close
    self.flush()
  File "C:\Python27\lib\socket.py", line 303, in flush
    self._sock.sendall(view[write_offset:write_offset+buffer_size])
error: [Errno 10053] An established connection was aborted by the software in yo
ur host machine
No to all of the above. Fresh install on this laptop and PMS/PlexConnect is the first thing I'm adding after crucial system drivers.
I just tried turning the Firewall back on, but opening ports 53 443 and 80 both TCP/UDP to both the inboubd and outbound rules just for good measure. The python.exe also shows.
In my log, it shows "DNS Request Received, Source: , (port number ranging from 40,000 to 65000) so I also open those ports as well just in case.
After playing around with it more, it seems the main issue is serving up the menus. I get a long wait anytime I navigate to a different menu or section. Once I finally get to the movie I want to watch and have the 'Play' button available to me, the movies load really quick and the 'Accessing Trailers' message shows for less than a second after clicking play.
So less than a second when finally playing a movie, but 1-3 minutes when using the menus.
Ok I solved the issue with long menu loading. I installed this version of Plexconnect https://github.com/iBaa/PlexConnect/archive/v0.5.zip from roidy's post here https://forums.plex.tv/topic/132734-massive-update-to-xml-selector-read-before-updating/
The version I downloaded yesterday  12/29/14 at 530pm central time was 0.5-dev according to my log files, I got it from this link https://github.com/iBaa/PlexConnect/archive/master.zip located on the github install guide here https://github.com/iBaa/PlexConnect/wiki/Install-Guide
With this version 0.5 I didnt have to go to 'unblock' all the *.py files. I just deleted the 0.5-dev files, extracted the 0.5 files and was ready to go after moving the certs back into the correct folder.
Thanks for your responses, and hope this helps someone else.
