Trailers unavailable. Try again later.
Here is all the info you guys will need. I've been working on this for a while all to no avail. I've tried google searching for answers, again to no avail. Hopefully you guys will know what's going on!
Thanks in advance,
Zack
Apple TV 2
Firmware 6.2.1
DNS Set on Apple TV: 192.168.2.60
IP of Plex Connect: 192.168.2.60
PlexConnect Server Info: Ubuntu 14.04.1 LTS
PMS Info: Windows 7
PMS Version: 0.9.11.4
PMS IP: 192.168.2.25
PlexConnect Version: Downloaded 12.09.14 at 6:40 CST
Contents of settings.cfg
[PlexConnect]
enable_plexgdm = True
ip_pms = 192.168.2.25
port_pms = 32400
enable_dnsserver = True
port_dnsserver = 53
ip_dnsmaster = 4.2.2.2
prevent_atv_update = True
enable_plexconnect_autodetect = True
ip_plexconnect = 0.0.0.0
hosttointercept = trailers.apple.com
port_webserver = 80
enable_webserver_ssl = True
port_ssl = 443
certfile = ./assets/certificates/trailers.pem
loglevel = High
logpath = .
Issue:
When Opening Trailers on Apple TV I receive the error: Trailers unavailable. Try again later.
I have tried unplugging and plugging apple tv - no go
I have re-created certs on PlexConnect Server - no go
PlexConnect.Log: http://pastebin.com/bCWJJ7vc
help? anyone? please?
Did you install the new cert on the atv?
10 hours? Really?
Certs? Firewall? On :443? Incoming/outgoing?
After recreating the certs on the server I reinstalled them by creating a new profile on the apple tv.
no firewall blocking 443.
Additional Info
also not having any issues with PMS inside or outside network
ATV and PlexConnect are inside the same network as PMS.
Having the same issue. Details posted below.
Firmware: ATV3 | 7.0.2 (6915)
DNS Set on Apple TV: 10.0.0.11
IP of PlexConnect: 10.0.0.12
PlexConnect Server Info: Windows 7 Professional x64
PMS Info: Windows 7 Professional x64
PMS IP: 10.0.0.11
PlexConnect Version: Downloaded 12.12.14 at 9:00 PM CST
enable_plexgdm = False
ip_pms = 10.0.0.11
port_pms = 32400
port_dnsserver = 53
ip_dnsmaster = 75.75.75.75
ip_plexconnect = 10.0.0.11
port_webserver = 80
port_ssl = 443
certfile = C:\Program Files\PlexConnect\assets\certificates railers.pem
loglevel = High
logpath = .
Issue:
I seem to be unable to get PlexConect to load the trailers application as expected. Once I select the trailers application it almost immediately displays "Trailers unavailable. Try again later." PMS is working otherwise find and I am able to access the PMS from other devices (local and offsite). I have had this working before but have had to re-install the OS and needed to set it up again. PlexConnect logs are attached.
PMS IP: 10.0.0.11
ip_pms = 10.0.0.11
port_pms = 32400
port_dnsserver = 53
port_webserver = 80
port_ssl = 443
loglevel = High
logpath = .
Issue:
Even though it seems the same issue, you should always start your own thread so all responses are to you.
However I would say it's an issue with your profile on the aTV as the log shows it intercepting the request.
Does that go for my log too?
. For some reason your log link won't open on my device so I can't say, but if you are seeing intercept received then Yes it would seem like a Profile issue on the aTV.
Both:
- might be Cert issue
- might be firewall related. What do you see when browsing to :80 and/or :443 from another device?
when going to :80 i get:
Error response
Error code 403.
Message: Not Serving Client 192.168.2.25.
Error code explanation: 403 = Request forbidden -- authorization will not help.
when going to :443 i get "this webpage not availible"
After reading previous posts, I tried re-installing the cert on the ATV again tonight to no avail.
Response to :80 is like expected.
For :443 you should see the same, potentially after overriding the browser's cert issue. To me it looks like port 443 is not correctly opened / still locked down by firewall or similar.
Apologies for the confusion. I have created a new, separate thread here.
I will respond to the posed questions provided there. Thanks.
The only firewall on my network is the one built into my modem / router.
The linux server I run PlexConnect on sits in the DMZ.
I added a rule directing traffic on 443 to the linux server's IP address, but honestly I didn't think this would matter since the ATV and the linux server are both behind this firewall.
Still no change.. :/
