All Library gone
Server Version#: 1.18.2.2058
Player Version#: 1.18.2.2058
Just recently all my library gone, just gone.
Now i created again all my libraries… this is really unacceptable.
What happen to plex now?
Is your media being stored on an external hard drive? I’d recommend using internal drives. If external drives are being used and the recycle bin functionality is turned on, i believe if the drive is disconnected while PMS is running, the library content will be deleted…
If a particular drive/folder used a library directory completely disappears, it intentionally does not remove info from data base, even if empty trash is turned on.
Without any details would only be making speculations. The logs files from whenever it happened would be best to see what might have happened.
all my media is internal as i have a multiple HDD in desktop windows server
Hi @Bigwheel,
I have multiple drive/folder for my media and all are gone in one instance.
Please share how to check the log files as you mentioned
thanks
