All media crashes playback after 10 seconds to 120 seconds
I don’t know which updated first. Either the Roku Plex app or the Desktop Server. I just know I updated the server when it didn’t play back to my Roku stick after I came back from vacation. I have tried rebuilding my library (It was pretty big). My server is running on an up-to-date Windows 10 Pro 64-bit PC. My files are held on an M.2 SSD drive. CPU is an AMD Ryzen 1600. I made a post in November when it broke before and over time it worked again without major issues. Now, it doesn’t work at all. So, any help from understanding the logs would be appreciated! I also enabled Remote Logging and tried to pull up a video to cause it to crash at 1:00 AM 02/26/20 Central Standard Time. It appears my Roku Television is also affected by this.
Before the question comes: Yes, I can play the videos fine locally and on web browser locally. No issues on the Plex player whatsoever. All the issues are between the Plex server and the Roku.
To bypass Plex I did try using DLNA via Serviio, but it began to crash the ffmpeg transcoder? So, It may be related to the ffmpeg libraries on my PC. I turned off the serviio server and restarted plex with DLNA. Plex DLNA was also not working properly when I attempted to stream and previously both worked. So, I don’t know what happened. It could be Transcoder related. Take a peek. Please. Help me.
Server Version#: 1.18.7.2457
Player Version#: 6.4 Build 10Logs.zip (11.0 MB) Logs.zip (11.0 MB)
