Server Version#: 1.41.6
Hello all.
I use Tdarr to convert files and store them in a global folder (tv/plex versions/optimized for tv). This worked fine, and still does for my movies folder with a similar setup.
However, suddenly (not sure exactly when, I didn’t change agents or anything, but have been continually adding and rescanning new optimized versions) it’s stopped working, and now all of the files match to a single show.
Any video file for season 1 episode 1 for any episode now registers as a different version of s01e01 of a single show.
Moving and re adding the files can change what show is the ‘main’ one, so it’s not an issue with that specific show.
I’ve tried moving all the files out and slowly adding them one by one (works for one show, but as soon as there’s two shows in the optimized folder it breaks). I’ve emptied trash, I’ve force redownloaded metadata, nothing is working.
As I said, this used to work fine for hundreds of episodes across tens of shows.
I’ve tried splitting the show, but that gives me the show with the original episode, and then another show with 10 versions of each episode, and I can’t split it further.
I should mention, the episodes are stored all in the optimised folder, not sub folders, but they are named with the show name, season/episode numbers, though in an inconsistent pattern.
Is there any way I can force plex to match differently? Or for me to manually specify the show these files are for?
I really don’t want to put the optimized files in show specific folders because as I said they come from tdarr, which has no (easy) way of knowing the show name based on the source file
Thanks in advance!
