I am enjoying the continue watching menu for the tv series. However I have noticed that when you go to the selected tv show from continue watching the shuffle feature for the entire show’s series isn’t available. You have to go back to the library pick the show again and then you are able to use the shuffle feature.
In what app are you missing this option?
If I open a show from the continue watching hub in Plex Web, that show record gives me the option to shuffle (though the command is located in the … context menu)
this is when I view it on the Plex client from my Samsung TV. The context menu is where I usually go to select the shuffle feature as well after selecting a show from the library but when you select the show from the client app on the samsung TV the shuffle feature isn’t available in the context menu for the show.
