Allow option to add tags and/or collections to Library folders
Libraries currently allow adding multiple folders.
It would be useful if, for each folder added under a library, you could add tags and/or collections.
Items that fall within that folder would then be automatically tagged and/or added to the collections specified.
This would support numerous use cases, and would be very flexible, while saving a lot of time manually tagging individual items.
There’s an existing feature suggestion aiming to reflect some folder structure when creating collections inside Plex. Though they’ve asked for a different approach.
I’m posting the link anyway for consistency :wink:
Thanks @tom80H!
Upon further reflection, I think the approach there is more flexible and granular.
I expanded on that approach with my own suggestion there:
As in making this one obsolete or being an alternate approach? :wink:
I now think this one is obsolete.
However, this one is likely much easier to implement :sweat_smile:
But, strategically the other approach is far superior, so best to focus on that I think
