Automatically show as Collections based on a folder structure?
Dear Plex devs
I understand the current folder structure for movies as the following:
/Media
   /Movies
      movie content
Unfortunately, current method of manually tagging each movie to be part of a collection is very labourious.
Would it be possible to recognise movies in a collection organised through a folder structure as below, to automatically show in Plex as Collections?
/Media
   /Movies
      /Collections
            /Collection name e.g. "Transformers (film series)"
                  movie content
Thanks and regards
Michael
@mcored said:
Dear Plex devs
/Media
   /Movies
      movie content
I so not see it as being particularly laborious at all.
All you need to do is use the web app and set it to folder view and then in each folder hover your mouse over the first item and the click the circle in the upper left corner then scroll to the last item and shift+click anywhere in the last item and then click the pencil icon on the upper right of the screen. In the edit menu go to tags and enter the collection you want all those files to be in. Repeat that action for each folder you want as a collection.
It took me about three times longer to type this than it takes to actually do it for a folder with 50-60 items and I am a fairly fast typist.
and you don’t even need to switch to the folder view to do this :wink:
Sorry guys, I have over hundreds of collections and what you are suggesting is simply a manual input.
Well it makes it easier if you have already placed your files in a folder structure that matches what you want for initial collection groupings. In the regular view movies are not necessarily grouped so the you can select all the ones you want with just a couple of clicks. I am all about ā€œeasy.ā€
ā€œMake everything as simple as possible, but not simpler.ā€ Albert Einstein
considering the massive shitstorm passing through when people complained about those auto-created collections from The Movie Database… yes.
Listen… I don’t disagree that having a folder representation of collections doesn’t make sense at all… it could be nice to e.g. store your local media assets such as posters / background images there – maybe in the future even collection extras.
however things are a little more complicated… what about movies you want to assign to multiple collections (e.g. for cross-overs or stuff like a Pixar collection and a Toy Story collection). Considering the manual follow-up/clean-up to get this sorted, I prefer the manual approach a lot.
I guess the confusion was probably because of user curated collections. I am not talking about those ones at all. May be this shouldn’t be called collections if that’s the case. I am only talking about ā€œfilm seriesā€, in Transformers example, only the movies listed here: Transformers (film series) - Wikipedia so a film series will only have those 5 movies (to-date) and nothing else.
So I were to ask the question again:
    /Media
       /Movies
          /Series
                /Series name e.g. "Transformers (film series)"
                      movie content
These could still appear in Collections, that’s fine. Users can manually input additional tags if they wanted to.
addition…
Personally I believe an actual improvement could be achieved by upping the collections matching w/ The Movie Database. The reason people were so annoyed wasn’t that Plex did find a collection… it was more about the unexpected addition of collections when you own only 1 movie of a set.
This can be fixed by extending the inline-collection configuration. There’s already a feature request asking for either a threshold (e.g. show only collections with more than 1 items) or maybe to add an additional option to the existing inline collection settings.
The big upside of a proper collection integration w/ The Movie Database is that they have the descriptions, posters, backgrounds etc. available right there.
THAT would make life super easy w/ collections :wink:
This is very interesting. Personally I would have liked Plex identifying a single movie as being part of a collection so I then know to follow up on a sequel. :smiley:
I believe the intention was for those 1-item collections still to show up in the dedicated collections view. Just not to see them inline with your movies.
So you could still track / follow up on the sequels.
Edit: here’s the feature request btw (in case you want to like it ;))
https://forums.plex.tv/discussion/304176/collections-minimum-threshold
It would be really nice to have custom collections that automatically update based on the folder. This would be really helpful for people who have a large collection of home videos and are continually adding videos into a predefined folder structure. It could also apply to Movies if you really wanted extra control.
For Example:
Home Video
  • Vacations(collection)
    ----2018(collection)
    ----2017(collection)
You could do this manually, but if you are adding several videos a month or week you’d have to continually update tags manually every time you add a new file, you would inevitably miss-tag or not tag a file resulting in incomplete collections. Being able to create custom collections based on relative file path would be a great power user feature.
Is this possible with regular tags? I think the feature would really only benefit power users who want to create customized library structures for a large, growing filebase.
I agree. I have been creating collections for my youtube downloaded content and it would be great for plex to automatically update the collection base on the directory that the content is located.
This dir = collection.
That way as I add new videos they are added to the collection and I do not need to go in and manually update all collections periodically.
If your files are using the mp4 format, use embedded meta tags.
Plex will read the content of the ā€˜Album’ meta tag and assign the video to the collection named after the Album.
Can I re-open this request please?
I used the manual process discussed above (select all movies in a folder, edit, add to collection) and that was fine, but now when I add new files to that folder, I have to repeat the process or tag each one manually. What a ball-ache.
I’d like to revisit this too - the manual process isn’t one I want to get into for the 130+ folders I’m trying to collection-ify. If someone hasn’t already, I’ll get working on a script this weekend
I totally agree… there should be a way to automatically generate collections from folders, at least as an option. It’s just too much manual work when it comest to anything other than movies. I have a ton of tutorials I collected along the years. A gazillion files in a gazillion folders. Everything nicely organized in a folder structure. But in order to have that in Plex I have to go through the same process again.
We just need a checkbox on the Library type details, like this:
[ ] Smart Folder - automatically add folder name as a collection tag
I don’t think anyone cares… as long as you pay for a Plex Pass the devs are happy. :man_shrugging:
The suggestion doesnĀ“t work when the movies are all in separate folders. Then folder view does nothing…
I suppose that is true. I never keep my movies in separate folders as, for me, I gain nothing and it just complicates maintenance for me.
