Allow to choose different version of a same movie
Hi all,
I'm not sure I'm at the right place but I have a suggestion for a feature.
When you have several version of the same movie, for exemple :
- One version in original language and one version in your own language,
- One theatrical version and one extended version,
- One 2D version and one 3D version,
- etc...
I only see one way to do it properly, duplicate the entrie in 2 libraries (or with the split appart fonction but it does not work on my synology).
It would be very usefull to add a feature allowing to choose the version I want to play, just as it is possible with subtitle.
Please help us with that feature, it is very not user friendly to have several entries for the same movie.
+1
Like the idea, had the same issue with my 3D movies recently and worked around with "duplicates". Didn't thought of theatrical and extended versions at that time, which would increase the amount of "duplicates"  :wacko: ...
Indeed it is not the place to ask for this king of features but here is where you can cast your vote.
