Allow "Track Skipped" to be applied in a larger span of time
It currently seems that the “Track Skipped” feature is only applied if you move to the next track between 15 and 30 seconds into the track.
I would really prefer this to be something like 5 and 60 seconds (or more). Could this window of time be configurable instead of hard-coded?
Scenario:
I like to listen to newly-added in a Smart Playlist (usually on ‘shuffle’).
After the end of a long listening session I would like to use the “Track Last Skipped” option in the advanced filters to find all of the tracks I skipped and rate them accordingly.
With the way that Plexamp currently seems to track the “Track Skipped”, it only catching a very small portion of the tracks that I’m skipping. I’m assuming I’m skipping a track at 5-10 seconds into a song most of the time… but I know I’ll listen to some songs and wait for the chorus to decide if it’s worth continuing to play… so I’ll skip many after the 30-second mark.
I’d really rather the window of time be configurable (or widened) to catch more “Track Skipped” moments.
