I have this same problem too.
Any known way to fix this?
known and reported to devs
Thanks @tom80H!!
Is that why I suddenly have no sorting options or alphabet in my shield libraries now? In the middle of fixing this?
doesn’t sound related.
Make sure your sort order at the top is set to Title otherwise it won’t show the letters.
Oh, actually I have no sorting options at all, no filters, just the library name. Though it is set to alphabetical based on the display of items. It really is an entirely separate issue I can see.
Are you by chance viewing your library „by folders“? In that case this is the normal behavior…
Nope, couldn’t even access folder view, that whole section of the UI is missing on my shield and mobile, it does show up on the web and kodi. Whole thing perplexing.
I am having the same issue on my Nvidia Shield as well. One day the alphabetical search was there, the next day it was gone. Very frustrating.
I am having the same issue. Alphabetical options were there one day and gone the next. Please issue a fix for this bug.
