I am using Amazon TV stick and cube. It always stops streaming after a few minutes. I have the Plex Pass. What do I need to do?
Provide details of your setup and logs from your server would be a good start, otherwise there is little that anyone can do to help you.
the plex server is running in ubuntu 18.04. It has 4 cores and 4 gb of ram.
Jul 21, 2018 16:11:07.338 [0x7f9fe4a63700] INFO - Processor Intel® Xeon® CPU E3-1225 v5 @ 3.30GHz
Jul 21, 2018 16:11:07.338 [0x7f9fe4a63700] INFO - /usr/lib/plexmediaserver/Plex Media Server
Jul 21, 2018 16:11:07.336 [0x7f9fd87fc700] DEBUG - Audio Stream: 2481, Subtitle Stream: -1
Jul 21, 2018 16:11:07.336 [0x7f9fd87fc700] DEBUG - We’re going to try to auto-select an audio stream for account 1.
Jul 21, 2018 16:11:07.336 [0x7f9fd87fc700] DEBUG - Selecting best audio stream for part ID 1317 (autoselect: 0 language: en)
Jul 21, 2018 16:11:07.336 [0x7f9fd87fc700] DEBUG - We’re going to try to auto-select a subtitle.
Jul 21, 2018 16:11:07.336 [0x7f9fd87fc700] DEBUG - Audio Stream: 2483, Subtitle Stream: -1
Jul 21, 2018 16:11:07.336 [0x7f9fd87fc700] DEBUG - Selecting best audio stream for part ID 1318 (autoselect: 0 language: en)
Jul 21, 2018 16:11:07.336 [0x7f9fd87fc700] DEBUG - Audio Stream: 2485, Subtitle Stream: -1
Jul 21, 2018 16:11:07.336 [0x7f9fd87fc700] DEBUG - Selecting best audio stream for part ID 1319 (autoselect: 0 language: en)
Jul 21, 2018 16:11:07.336 [0x7f9fd87fc700] DEBUG - Audio Stream: 2487, Subtitle Stream: -1
Jul 21, 2018 16:11:07.336 [0x7f9fd87fc700] DEBUG - Selecting best audio stream for part ID 1320 (autoselect: 0 language: en)
Jul 21, 2018 16:11:07.336 [0x7f9fd87fc700] DEBUG - Audio Stream: 2489, Subtitle Stream: -1
Jul 21, 2018 16:11:07.337 [0x7f9fd87fc700] DEBUG - We’re going to try to auto-select an audio stream for account 1.
Jul 21, 2018 16:11:07.337 [0x7f9fd87fc700] DEBUG - Selecting best audio stream for part ID 1321 (autoselect: 0 language: en)
I see this when it stop working.
Also streaming from ipad and the web works perfectly fine. I have the same behavior when it is streaming from amazon tv stick and amazon cube. On both Amazon devices, it stops after a few minutes.
any help would greatly appreciated.
