Ich kann mir einiges zusammenreimen aber verstehen werde ich es ohne Hilfe nicht.
Jan 22, 2018 14:20:48.563 [0x7f8d50fff700] DEBUG - MDE: Selected protocol hls; container: mpegts
Jan 22, 2018 14:20:48.563 [0x7f8d50fff700] DEBUG - MDE: analyzing media item 325288
Jan 22, 2018 14:20:48.563 [0x7f8d50fff700] DEBUG - MDE: Baywatch (2017): Direct Play is disabled
Jan 22, 2018 14:20:48.563 [0x7f8d50fff700] DEBUG - MDE: Baywatch (2017): media must be transcoded in order to use the hls protocol
Jan 22, 2018 14:20:48.563 [0x7f8d50fff700] DEBUG - MDE: Baywatch (2017): no direct play video profile exists for http/mkv/hevc
Jan 22, 2018 14:20:48.563 [0x7f8d50fff700] DEBUG - MDE: Baywatch (2017): no direct play video profile exists for http/mkv/hevc/truehd
Jan 22, 2018 14:20:48.564 [0x7f8d50fff700] DEBUG - MDE: Baywatch (2017): selected media 0 / 325288
Jan 22, 2018 14:20:48.564 [0x7f8d50fff700] DEBUG - Streaming Resource: Changing decision parameters to fit bandwidth limit of 2000kbps
Jan 22, 2018 14:20:48.564 [0x7f8d50fff700] DEBUG - Codecs: testing h264_qsv (encoder)
Jan 22, 2018 14:20:48.565 [0x7f8d50fff700] DEBUG - Codecs: hardware transcoding: testing API qsv
Jan 22, 2018 14:20:48.565 [0x7f8d50fff700] ERROR - [FFMPEG] - No VA display found for device: .
Jan 22, 2018 14:20:48.565 [0x7f8d50fff700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Invalid argument
Jan 22, 2018 14:20:48.565 [0x7f8d50fff700] DEBUG - Codecs: testing h264_vaapi (encoder)
Jan 22, 2018 14:20:48.566 [0x7f8d50fff700] DEBUG - Codecs: hardware transcoding: testing API vaapi
Jan 22, 2018 14:20:48.566 [0x7f8d50fff700] ERROR - [FFMPEG] - No VA display found for device: /dev/dri/renderD128.
Jan 22, 2018 14:20:48.566 [0x7f8d50fff700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Invalid argument
Jan 22, 2018 14:20:48.566 [0x7f8d50fff700] DEBUG - Codecs: testing h264_nvenc (encoder)
Jan 22, 2018 14:20:48.567 [0x7f8d50fff700] ERROR - [FFMPEG] - Cannot load libcuda.so.1
Jan 22, 2018 14:20:48.567 [0x7f8d50fff700] WARN - avcodec_open2 returned -1313558101 for encoder ‘h264_nvenc’
Jan 22, 2018 14:20:48.567 [0x7f8d50fff700] DEBUG - Codecs: hardware transcoding: testing API vaapi
Jan 22, 2018 14:20:48.567 [0x7f8d50fff700] ERROR - [FFMPEG] - No VA display found for device: /dev/dri/renderD128.
Jan 22, 2018 14:20:48.567 [0x7f8d50fff700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Invalid argument
Jan 22, 2018 14:20:48.567 [0x7f8d50fff700] DEBUG - Scaled up video bitrate to 52492Kbps based on 4.500000x fudge factor.
Jan 22, 2018 14:20:48.568 [0x7f8d50fff700] DEBUG - MDE: Selected protocol hls; container: mpegts
Jan 22, 2018 14:20:48.568 [0x7f8d50fff700] DEBUG - MDE: analyzing media item 325288
Jan 22, 2018 14:20:48.568 [0x7f8d50fff700] DEBUG - MDE: Baywatch (2017): Direct Play is disabled
Jan 22, 2018 14:20:48.568 [0x7f8d50fff700] DEBUG - MDE: Baywatch (2017): media must be transcoded in order to use the hls protocol
Jan 22, 2018 14:20:48.568 [0x7f8d50fff700] DEBUG - MDE: Baywatch (2017): no direct play video profile exists for http/mkv/hevc
Jan 22, 2018 14:20:48.568 [0x7f8d50fff700] DEBUG - MDE: Baywatch (2017): no direct play video profile exists for http/mkv/hevc/truehd
Jan 22, 2018 14:20:48.568 [0x7f8d50fff700] DEBUG - MDE: Baywatch (2017): Direct Streaming is disabled, so video stream will be transcoded
Jan 22, 2018 14:20:48.568 [0x7f8d50fff700] DEBUG - MDE: Baywatch (2017): no remuxable profile found, so video stream will be transcoded
Jan 22, 2018 14:20:48.568 [0x7f8d50fff700] DEBUG - Codecs: testing h264_nvenc (encoder)
Jan 22, 2018 14:20:48.569 [0x7f8d50fff700] ERROR - [FFMPEG] - Cannot load libcuda.so.1
Jan 22, 2018 14:20:48.569 [0x7f8d50fff700] WARN - avcodec_open2 returned -1313558101 for encoder ‘h264_nvenc’
Jan 22, 2018 14:20:48.569 [0x7f8d50fff700] DEBUG - Codecs: hardware transcoding: testing API vaapi
Jan 22, 2018 14:20:48.569 [0x7f8d50fff700] ERROR - [FFMPEG] - No VA display found for device: /dev/dri/renderD128.
Jan 22, 2018 14:20:48.569 [0x7f8d50fff700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Invalid argument
Jan 22, 2018 14:20:48.569 [0x7f8d50fff700] DEBUG - Scaled up video bitrate to 52492Kbps based on 4.500000x fudge factor.
Jan 22, 2018 14:20:48.570 [0x7f8d50fff700] DEBUG - MDE: Baywatch (2017): Audio Direct Streaming is disabled, so video’s audio stream will be transcoded
Jan 22, 2018 14:20:48.570 [0x7f8d50fff700] DEBUG - MDE: Baywatch (2017): selected media 0 / 325288
Jan 22, 2018 14:20:48.570 [0x7f8d50fff700] DEBUG - Streaming Resource: Reducing playback quality for 1904kbps stream bitrate: video resolution to 720x406, audio channels to 2, quality to 41
Jan 22, 2018 14:20:48.570 [0x7f8d50fff700] DEBUG - Codecs: testing h264_nvenc (encoder)
Jan 22, 2018 14:20:48.571 [0x7f8d50fff700] ERROR - [FFMPEG] - Cannot load libcuda.so.1
