Analyzing Library
HI, I finally got to set up my whole library of tv shows and movies. But I’m sure that some chapters are missing in some series. Is there any programe or option that will notify or make a list of chapters missing in the library?
Thanks!
If you are a new user, you should definitely take a look at this:
https://support.plex.tv/hc/en-us/articles/201543057-Why-is-some-of-my-content-not-found-
Do you mean by that
  1. you don’t have all files for all episodes of the tv show
  2. Plex did not recognise all episodes of the show
  3. can be avoided by following the naming guide for tv shows
There is also a Plex plugin which checks for media files not recognised by Plex:
https://forums.plex.tv/discussion/87745/rel-find-unmatched-items/p1#top
it can be installed like this:
https://support.plex.tv/hc/en-us/articles/201187656-How-do-I-manually-install-a-channel-
Hi thanks for your fast answer!
PLex is working fine and recognises all my files. But I mean number 1 you mention. I was watching 24 season 2 and i was missing chapter 4. is there something that will scan my library and make a file or report with the chapters i am missing?
Not to my knowledge, no.
