Android 2026.5.0 - Play queue becomes impossible to hide
Server Version#:
Player Version#: 2026.5.0
The play queue can become nearly impossible to hide. Tapping the arrow to bring it up works, and then it automatically hides itself okay when somewhere else is tapped on the screen. But if I drag a bit up from the bottom of the screen, the play queue comes up and then tapping anywhere on the screen or dragging downwards anywhere doesn’t hide it.
Video demonstration of the problem.
+1 Also experiencing this. This release has been very buggy
+1 I’m seeing this as well, even running from GrapheneOS.
It is a known issue reported recently. Sorry I don’t have eta.
From our reproducing it happens when swiping up from bottom. If you select the down arrow below the scrub bar to bring it up it should go away then.
