Playback controls don't fade out
Server Version#: 1.18.0.1846
Player Version#: 7.23.0.12806
Hello,
I recently noticed that the playback controls could not be hidden anymore using a simple tap on screen.
They still disappear after 4 seconds on their own, but, and here’s the real problem, once you used the seeking bar they get stuck in shown position and never disappear on their own again until you restart the playback.
On plex for Android OnePlus 5T
I made a video of this bug
Logs: plex-log-paolovador.zip (248.1 KB)
It’s working fine on stable 7.22.1.12828
Maybe it was your change regarding:
[Mobile] Player: user-interface stays hidden when starting playback or
[Mobile] Player: ensure tapping on the seekbar doesn’t show seek previews
in the 7.23.0.12762-beta - Android (mobile) beta release notes that started this problem ?
Thanks for reporting! We’ll try to fix this in one of the next betas!
We released a new beta that should fix this issue: Android (mobile) beta release notes.
Thanks again and sorry for the inconvenience!
Great I’ll check it out
Thanks for your hard work dev team, I can confirm this is fixed in 7.23.0.12902-beta as promised !
