Ah good point, if thats the case can you DM me the unreplaced logs.
Yes I replaced it, I sent you the domain name by DM
Always buggy on 8.1.0.17759-beta @sixones
Same bug with build 8.1.0.17797-beta @sixones
Not fixed in 8.1.0.17833-beta
Build 8.1.0.17893-beta don’t fix it
I had a similar problem that I discovered was due to an expiring Comodo/Sectigo certificate. See this gist:
sectigo.md
# Comodo/Sectigo/USERTrust/AddTrust root certificate expiry
On May 30th 2020 (10:48am GMT / 6:48am EDT / 3:48am PDT), a root certificate and an intermediate certificate that were part of the Comodo/Sectigo family expired.
## The expired certificates
The following 2 certificates expired on __May 30 10:48:38 2020 GMT__:
- [AddTrust External CA Root](https://crt.sh/?id=1) _(Type:Root)_ _(Serial:`1`)_
- [USERTrust RSA Certification Authority](https://crt.sh/?id=4860286) _(Type:Intermediate)_ _(Serial:`13:ea:28:70:5b:f4:ec:ed:0c:36:63:09:80:61:43:36`)_
This file has been truncated. show original
After some tests we confirmed there is an issue with the HLS demuxer when the start.m3u8 request is forwarded (using 302) to a server with another certificate.
Like cloudflare => 302 => Letsencrypt
Any news about the HLS demuxer config @sixones ?
Any news from Plex Team ?
It seems that the same errors occurs on iOS with the experimental player
2020/06/11 16:56:15.609 (126 MB) (2798631) PMKMPVClient.m:477 | [ffmpeg] error: tls: Unable to negotiate TLS/SSL session: -9807
It works on Android build 8.3.0.18653-beta . Thanks for your time and the bugfix @sixones
Plex for Android 8.3.0.18653-beta
Available on Google Play .
WHATS NEW:
Add support for server update notification.
Play on deck episode from show and season preplay screen when applicable.
Player: Sleep Timer support for video
Watch Together: support for inviting friends during playback.
FIXES:
Player: start loading the next video once the postplay hides.
Player: prevent Skip Intro from appearing during postplay.
Player: improve startup speed by removing unncessary network request.
Player…
system
Closed
September 20, 2020, 10:14pm
35
