Android Home Screen is not rendering, shows a refresh symbol instead
Server Version#: Version 3.77.2
Player Version#:7.28.0.1.15501 (ba34f115)
Android App on Huawei P30 Pro had the issue where the home screen just shows a refresh symbol and no content.
My previously playing music was present, when I closed it down because I saw something was wrong I could not get back to it.
I followed the instructions to reset the Home screen (using the 3 dots). Did this and got my menu back, can now access content. but my home screen still just shows the yellow/orange refresh symbol.
It has been like this for a few days now and possibly a long time before.
The yellow refresh symbol is the same one the appears while screens are loading, For example same as the one when selecting Users and Sharing
Not fixed but found a away to make it go away.
As well as the 3 dot then reset all customisations (assume that was meant to do what I am about to describe).
As well as that, I went to settings, then Experience, then Application Layout, I changed it to TV.
It prompted me that the application wpould restart, I choose yes, when it restarted, and I touched the screen, it warned me that TV mode is not touch capable do I want to switch back to mobile
I chose SWITCH TO MOBILE
BACK TO NORMAL.
But gotta say, how did the devs let that happen.
OK, so today after getting it back to normal yesterday (to be clear yesterday was not a fix).
I was listening to music and it just stopped mid song.
Seems like Pex cannot handle music. Lots of articles about plex does not do music very well.
Music stopped but also the App home and app menu died again lost all their settings.
reset All customisations brought back the menu items and gave me back access but it did not repair the Home Screen. Not going to repair home screen, just gonna see how it goes for a day or 2.
  1. Music just stopped again, and the track time went back to 0.
    So it lasted 20min since I last start playing.
    when I logged in a gain the home screen was back also.
  2. Later, died again…
This is crap!
Constantly getting these errors in my Server Log:
Not sure what they mean, also not sure if I should be looking at Server logs or player logs???
Feb 24, 2020 14:21:13.418 [0x7ff4a700] WARN - NAT: PMP, got an error: Not Supported by gateway.
Feb 24, 2020 14:25:42.360 [0x7ff41700] DEBUG - NotificationStream: Removing because of error
Here are my logs when the music just stops and sets back to the beginning, but also requires me to login again (which is fine but annoying:
Feb 24, 2020 15:05:30.708 [0x7ff44194f700] DEBUG - Play progress on 11640 ‘Walkin’ On The Sun’ - got played 170002 ms by account 1!
Feb 24, 2020 15:05:30.710 [0x7ff44194f700] DEBUG - [Now] User is qwikag (ID: 1)
Feb 24, 2020 15:05:30.710 [0x7ff44194f700] DEBUG - [Now] Device is Android (P30 Pro).
Feb 24, 2020 15:05:30.710 [0x7ff44194f700] DEBUG - [Now] Profile is Android
Feb 24, 2020 15:05:30.710 [0x7ff44194f700] DEBUG - [Now] Updated play state for /library/metadata/11640.
Feb 24, 2020 15:05:30.710 [0x7ff44194f700] DEBUG - Statistics: (7a01f93453d72672-com-plexapp-android) Reporting active playback in state 0 of type 10 (scrobble: 0) for account 1
Feb 24, 2020 15:05:30.711 [0x7ff44194f700] VERBOSE - It took 0.0 sec to serialize a list with 0 elements.
Feb 24, 2020 15:05:30.712 [0x7ff442150700] DEBUG - Completed: [IP:51797] 200 GET /:/timeline?bufferedTime=34998&duration=418000&guid=com.plexapp.agents.plexmusic%3A%2F%2Fgracenote%2Ftrack%2F23099814-C31E943693B58C8D0201026A4EDFB41E%2F23099829-B650F0C1D95F34837EBC5A38DEF873DD%3Flang%3Den&key=%2Flibrary%2Fmetadata%2F11640&playbackTime=169778&playQueueItemID=80914&ratingKey=11640&state=playing&time=170002&token=xxxxxxxxxxxxxxxxxxxx (5 live) TLS GZIP 6ms 460 bytes (pipelined: 18)
Feb 24, 2020 15:05:31.725 [0x7ff442150700] VERBOSE - WebSocket: processed 1 frame(s)
Feb 24, 2020 15:05:36.334 [0x7ff442150700] VERBOSE - WebSocket: processed 1 frame(s)
Feb 24, 2020 15:05:40.705 [0x7ff442150700] VERBOSE - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Feb 24, 2020 15:05:40.705 [0x7ff442150700] DEBUG - Auth: authenticated user 1 as qwikag
Feb 24, 2020 15:05:40.705 [0x7ff442150700] VERBOSE - Auth: Came in with a super-token, authorization succeeded.
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] DEBUG - Request: [CELLIPADDRESS:51797 (WAN)] GET /:/timeline?bufferedTime=24996&duration=418000&guid=com.plexapp.agents.plexmusic%3A%2F%2Fgracenote%2Ftrack%2F23099814-C31E943693B58C8D0201026A4EDFB41E%2F23099829-B650F0C1D95F34837EBC5A38DEF873DD%3Flang%3Den&key=%2Flibrary%2Fmetadata%2F11640&playbackTime=179784&playQueueItemID=80914&ratingKey=11640&state=playing&time=180004&token=xxxxxxxxxxxxxxxxxxxx (5 live) TLS GZIP Signed-in Token (qwikag)
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * Accept => application/xml
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * Accept-Encoding => gzip
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * Accept-Language => en-nz
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * Connection => Keep-Alive
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * Host => HOST IPADDRESS.f883030c375c4e40a03c9d36ee0f0fc7.plex.direct:42400
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * User-Agent => Dalvik/2.1.0 (Linux; U; Android 9; VOG-L09 Build/HUAWEIVOG-L09)
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * X-Plex-Advertising-DoNotTrack => 0
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * X-Plex-Advertising-Identifier => 7e1f6982-bfda-4805-b75f-09688dc78eb0
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * X-Plex-Client-Identifier => 7a01f93453d72672-com-plexapp-android
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * X-Plex-Device => VOG-L09
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * X-Plex-Device-Name => P30 Pro
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * X-Plex-Device-Screen-Density => 408
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * X-Plex-Device-Screen-Resolution => 2340x1080 (Mobile)
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * X-Plex-Device-Vendor => HUAWEI
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * X-Plex-DRM => widevine:video
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * X-Plex-Features => external-media
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * X-Plex-Model => HWVOG
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * X-Plex-Online => 1
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * X-Plex-Platform => Android
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * X-Plex-Platform-Version => 9
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * X-Plex-Product => Plex for Android (Mobile)
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * X-Plex-Provider-Version => 1.3.0
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * X-Plex-Provides => player,pubsub-player,controller,sync-target
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * X-Plex-Token => xxxxxxxxxxxxxxxxxxxx
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * X-Plex-Username => qwikag
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * X-Plex-Version => 7.28.0.15501
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * bufferedTime => 24996
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * duration => 418000
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * guid => com.plexapp.agents.plexmusic://gracenote/track/23099814-C31E943693B58C8D0201026A4EDFB41E/23099829-B650F0C1D95F34837EBC5A38DEF873DD?lang=en
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * key => /library/metadata/11640
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * playbackTime => 179784
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * playQueueItemID => 80914
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * ratingKey => 11640
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * state => playing
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * time => 180004
Feb 24, 2020 15:05:40.705 [0x7ff44194f700] VERBOSE - * token => xxxxxxxxxxxxxxxxxxxx
Feb 24, 2020 15:05:40.707 [0x7ff44194f700] DEBUG - Client [7a01f93453d72672-com-plexapp-android] reporting timeline state playing, progress of 180004/418000ms for guid=com.plexapp.agents.plexmusic://gracenote/track/23099814-C31E943693B58C8D0201026A4EDFB41E/23099829-B650F0C1D95F34837EBC5A38DEF873DD?lang=en, playbackTime=179784ms ratingKey=11640 url=, key=/library/metadata/11640, containerKey=, metadataId=11640, source=
Feb 24, 2020 15:05:40.708 [0x7ff44194f700] DEBUG - Play progress on 11640 ‘Walkin’ On The Sun’ - got played 180004 ms by account 1!
Feb 24, 2020 15:05:40.711 [0x7ff44194f700] DEBUG - [Now] User is qwikag (ID: 1)
Feb 24, 2020 15:05:40.711 [0x7ff44194f700] DEBUG - [Now] Device is Android (P30 Pro).
Feb 24, 2020 15:05:40.712 [0x7ff44194f700] DEBUG - [Now] Profile is Android
Feb 24, 2020 15:05:40.712 [0x7ff44194f700] DEBUG - [Now] Updated play state for /library/metadata/11640.
Feb 24, 2020 15:05:40.712 [0x7ff44194f700] DEBUG - Statistics: (7a01f93453d72672-com-plexapp-android) Reporting active playback in state 0 of type 10 (scrobble: 0) for account 1
Feb 24, 2020 15:05:40.715 [0x7ff44194f700] VERBOSE - It took 0.0 sec to serialize a list with 0 elements.
Feb 24, 2020 15:05:40.715 [0x7ff442150700] DEBUG - Completed: [CELLIPADDRESS:51797] 200 GET /:/timeline?bufferedTime=24996&duration=418000&guid=com.plexapp.agents.plexmusic%3A%2F%2Fgracenote%2Ftrack%2F23099814-C31E943693B58C8D0201026A4EDFB41E%2F23099829-B650F0C1D95F34837EBC5A38DEF873DD%3Flang%3Den&key=%2Flibrary%2Fmetadata%2F11640&playbackTime=179784&playQueueItemID=80914&ratingKey=11640&state=playing&time=180004&token=xxxxxxxxxxxxxxxxxxxx (5 live) TLS GZIP 10ms 459 bytes (pipelined: 19)
Feb 24, 2020 15:05:41.725 [0x7ff442150700] VERBOSE - WebSocket: processed 1 frame(s)
Feb 24, 2020 15:05:46.578 [0x7ff442150700] VERBOSE - WebSocket: processed 1 frame(s)
Feb 24, 2020 15:05:47.276 [0x7ff442150700] DEBUG - handleStreamRead code 335544539: short read
Feb 24, 2020 15:05:47.276 [0x7ff442150700] DEBUG - NotificationStream: Removing because of error
Feb 24, 2020 15:05:47.276 [0x7ff442150700] DEBUG - Completed after connection close: [CELLIPADDRESS:51616] -3 GET /:/websockets/notifications (4 live) TLS GZIP 181021ms 6921 bytes
Feb 24, 2020 15:05:51.725 [0x7ff442951700] VERBOSE - WebSocket: processed 1 frame(s)
Feb 24, 2020 15:06:01.725 [0x7ff442150700] VERBOSE - WebSocket: processed 1 frame(s)
Cut the Log in half here because this is about where it just stoped.
Feb 24, 2020 15:06:10.485 [0x7ff4327fc700] DEBUG - EPG[xmltv]: Purging 0 airings which completed in the past.
Feb 24, 2020 15:06:11.725 [0x7ff442951700] VERBOSE - WebSocket: processed 1 frame(s)
Feb 24, 2020 15:06:21.726 [0x7ff442150700] VERBOSE - WebSocket: processed 1 frame(s)
Feb 24, 2020 15:06:29.080 [0x7ff442150700] VERBOSE - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Feb 24, 2020 15:06:29.080 [0x7ff442150700] DEBUG - Auth: authenticated user 1 as qwikag
Feb 24, 2020 15:06:29.080 [0x7ff442150700] VERBOSE - Auth: Came in with a super-token, authorization succeeded.
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] DEBUG - Request: [CELLIPADDRESS:52083 (WAN)] GET / (4 live) TLS GZIP Signed-in Token (qwikag)
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] VERBOSE - * Accept => application/xml
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] VERBOSE - * Accept-Encoding => gzip
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] VERBOSE - * Accept-Language => en-nz
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] VERBOSE - * Connection => Keep-Alive
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] VERBOSE - * Host => HOST IPADDRESS.f883030c375c4e40a03c9d36ee0f0fc7.plex.direct:42400
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] VERBOSE - * User-Agent => Dalvik/2.1.0 (Linux; U; Android 9; VOG-L09 Build/HUAWEIVOG-L09)
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] VERBOSE - * X-Plex-Advertising-DoNotTrack => 0
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] VERBOSE - * X-Plex-Advertising-Identifier => 7e1f6982-bfda-4805-b75f-09688dc78eb0
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] VERBOSE - * X-Plex-Client-Identifier => 7a01f93453d72672-com-plexapp-android
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] VERBOSE - * X-Plex-Device => VOG-L09
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] VERBOSE - * X-Plex-Device-Name => P30 Pro
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] VERBOSE - * X-Plex-Device-Screen-Density => 408
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] VERBOSE - * X-Plex-Device-Screen-Resolution => 2340x1080 (Mobile)
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] VERBOSE - * X-Plex-Device-Vendor => HUAWEI
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] VERBOSE - * X-Plex-DRM => widevine:video
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] VERBOSE - * X-Plex-Features => external-media
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] VERBOSE - * X-Plex-Model => HWVOG
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] VERBOSE - * X-Plex-Online => 0
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] VERBOSE - * X-Plex-Platform => Android
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] VERBOSE - * X-Plex-Platform-Version => 9
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] VERBOSE - * X-Plex-Product => Plex for Android (Mobile)
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] VERBOSE - * X-Plex-Provider-Version => 1.3.0
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] VERBOSE - * X-Plex-Provides => player,pubsub-player,controller,sync-target
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] VERBOSE - * X-Plex-Token => xxxxxxxxxxxxxxxxxxxx
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] VERBOSE - * X-Plex-Username => qwikag
Feb 24, 2020 15:06:29.080 [0x7ff44194f700] VERBOSE - * X-Plex-Version => 7.28.0.15501
Feb 24, 2020 15:06:29.081 [0x7ff44194f700] DEBUG - (Capabilities) Platform ‘Android’ not matched by plugin platform requirements
Feb 24, 2020 15:06:29.081 [0x7ff44194f700] VERBOSE - It took 0.0 sec to serialize a list with 25 elements.
Feb 24, 2020 15:06:29.082 [0x7ff442150700] DEBUG - Completed: [CELLIPADDRESS:52083] 200 GET / (4 live) TLS GZIP 1ms 3438 bytes (pipelined: 1)
Feb 24, 2020 15:06:29.126 [0x7ff442951700] VERBOSE - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Feb 24, 2020 15:06:29.127 [0x7ff442951700] DEBUG - Auth: authenticated user 1 as qwikag
Feb 24, 2020 15:06:29.127 [0x7ff442951700] VERBOSE - Auth: Came in with a super-token, authorization succeeded.
IS VERBOSE USEFUL?
Stopped Again! - while streaming on Local Network
Feb 24, 2020 16:25:53.071 [0x7ff3f8ff9700] DEBUG - Play progress on 11695 ‘Sussudio’ - got played 70094 ms by account 1!
Feb 24, 2020 16:25:53.075 [0x7ff3f8ff9700] DEBUG - [Now] User is qwikag (ID: 1)
Feb 24, 2020 16:25:53.075 [0x7ff3f8ff9700] DEBUG - [Now] Device is Android (P30 Pro).
Feb 24, 2020 16:25:53.076 [0x7ff3f8ff9700] DEBUG - [Now] Profile is Android
Feb 24, 2020 16:25:53.076 [0x7ff3f8ff9700] DEBUG - [Now] Updated play state for /library/metadata/11695.
Feb 24, 2020 16:25:53.076 [0x7ff3f8ff9700] DEBUG - Statistics: (7a01f93453d72672-com-plexapp-android) Reporting active playback in state 0 of type 10 (scrobble: 0) for account 1
Feb 24, 2020 16:25:53.084 [0x7ff442951700] DEBUG - Completed: [Local IP:42514] 200 GET /:/timeline?bufferedTime=192905&duration=356000&guid=com.plexapp.agents.plexmusic%3A%2F%2Fgracenote%2Ftrack%2F7308312-3A004644047A617CE9C83E649A2D4253%2F477669069-E7C1183D280D0DA8E528102AC27835FD%3Flang%3Den&key=%2Flibrary%2Fmetadata%2F11695&playbackTime=69926&playQueueItemID=80931&ratingKey=11695&state=playing&time=70094&token=xxxxxxxxxxxxxxxxxxxx (5 live) TLS GZIP 16ms 459 bytes (pipelined: 74)
Feb 24, 2020 16:26:01.698 [0x7ff442150700] DEBUG - handleStreamRead code 335544539: short read
Feb 24, 2020 16:26:01.698 [0x7ff442150700] DEBUG - NotificationStream: Removing because of error
Feb 24, 2020 16:26:01.698 [0x7ff442150700] DEBUG - Completed after connection close: [Local IP:42518] -3 GET /:/websockets/notifications (5 live) TLS GZIP 647293ms 23592 bytes
Have logged a new Post for this music stopping shinanigans.
