Hello,
When playing a music library on random, playback starts, show the cover art and all that stuff, then skips to the next song showing “Une erreur s’est produite pendant la lecture de ce fichier” (An error happened during the file playback - search for that in the logs below).
I have the same problem on 2 other phones.
Server Version#: 1.24.3.5033
Player Version#: 8.23.1.28053 (f4932f7a)
Relevent client logs follow
09-29 20:36:58.920 i: [Player][Timeline] Playback started (or buffering), scheduling updates
09-29 20:36:58.921 w: [Player][Timeline] player position was negative. Position time will be reported as 0.
09-29 20:36:58.923 i: [PlaybackTimeBehaviour] Time: 409 IsStarted: false
09-29 20:36:58.927 i: [PlaybackTimeBehaviour] Initialising
09-29 20:36:58.928 i: [PlaybackTimeBehaviour] Starting stopwatch
09-29 20:36:58.928 i: [AudioFocusBehaviour] Playback started
09-29 20:36:58.928 i: [PlayQueueProgressBehaviour] Updating PlayQueueManager state, isPlaying: true
09-29 20:36:58.928 i: [PlayQueueBehaviour] Clearing video PQ because audio playback has started.
09-29 20:36:58.935 i: Fetching [method:GET] https://plex.*****.com:443/:/timeline?bufferedTime=6428&duration=268000&guid=plex%3A%2F%2Ftrack%2F5d07cd92403c640290f1bcb3&key=%2Flibrary%2Fmetadata%2F182386&playbackTime=409&playQueueItemID=9954436&ratingKey=182386&state=playing&time=0&token=...J9Na&X-Plex-Client-Identifier=b36985684de1507d-com-plexapp-android&X-Plex-Token=...J9Na&X-Plex-Language=fr-fr
09-29 20:36:58.938 i: [WiFiLockBehaviour] Aquiring WiFi lock since playback was started.
09-29 20:36:58.940 i: [BatteryMonitorBehaviour] Starting playback with 2081331 µAh (56%).
09-29 20:36:58.945 i: [MediaSessionBehaviour] Updating state to PLAYING
09-29 20:36:58.945 i: [Player] onPlaybackStarted
09-29 20:36:58.945 i: [Treble]: BASS: Resume.
09-29 20:36:58.946 i: [PlayQueueProgressBehaviour] Item completed, moving to next PlayQueue item
09-29 20:36:58.946 i: [PlayQueueAPIHelperBase] Retrieving play queue (id: 3402, repeat: 0).
09-29 20:36:58.946 i: Fetching [method:GET] https://plex.******.com:443/playQueues/3402?center=9954436&includeLoudnessRamps=1&repeat=0&X-Plex-Token=...J9Na&X-Plex-Language=fr-fr
09-29 20:36:58.946 i: [Player][Treble] Removing already played track: 9954435
09-29 20:36:58.946 i: [Treble]: BASS: Asked to remove stream with identifier 9954435 with 2 existing streams (fade: 1, kickOffNext: 1).
09-29 20:36:58.947 i: [Treble]: PQCache: Set item 9954435 active to 0, 1 active remaining.
09-29 20:36:58.947 i: [Treble]: BASS: Removed stream 9954435 from position 0, there are now 1 streams.
09-29 20:36:58.947 i: [Treble]: Cache: Asked to close file.
09-29 20:36:58.947 w: [Player][Timeline] player position was negative. Position time will be reported as 0.
09-29 20:36:58.948 i: [PlaybackTimeBehaviour] Time: 20 IsStarted: true
09-29 20:36:58.948 w: [Player][Timeline] Ignoring timeline update, as less than 8 seconds has passed since last update without any state change.
09-29 20:36:58.948 i: [WiFiLockBehaviour] Releasing WiFi lock since playback was stopped.
09-29 20:36:58.948 i: [Player][Treble] onRuntimeSessionOptionsChanged
09-29 20:36:58.948 i: Fetching [method:GET] https://plex.****:443/library/streams/286993/levels?subsample=256&X-Plex-Token=...J9Na&X-Plex-Language=fr-fr
09-29 20:36:58.949 i: [BatteryMonitorBehaviour] Playback session was 0,0 minutes long.
09-29 20:36:58.949 i: [BatteryMonitorBehaviour] Average battery consumption was 0,00 µAh per minute.
09-29 20:36:58.952 i: [MediaSessionBehaviour] Updating state to STOPPED
09-29 20:36:58.952 i: [MediaSessionBehaviour] Releasing MediaSessionHelper
09-29 20:36:58.964 i: [Player][Timeline] Player error not known by server, reporting original player error (or a playback interrupted one)
09-29 20:36:58.965 i: [Player] Error reported: TransientError (null)
09-29 20:36:58.965 i: [Player][Timeline] Playback stopped (error: false)
09-29 20:36:58.965 w: [Player][Timeline] player position was negative. Position time will be reported as 0.
09-29 20:36:58.967 i: [PlaybackTimeBehaviour] Time: 38 IsStarted: true
09-29 20:36:58.968 i: [MediaSessionBehaviour] Current item has changed
09-29 20:36:58.969 i: [CurrentItemMetadataBehaviour] Fetching current item
09-29 20:36:58.969 i: Fetching [method:GET] https://plex.*****.com:443/library/metadata/182386?includeChapters=1&includeLoudnessRamps=1&includeMarkers=1&includeRelated=1&X-Plex-Token=...J9Na&X-Plex-Language=fr-fr
09-29 20:36:58.970 i: [MediaSessionBehaviour] Updating metadata for music, thumb: false
09-29 20:36:58.972 i: Showing toast: Une erreur s'est produite pendant la lecture de ce fichier.
09-29 20:36:58.978 i: [EngineEventManager] onBufferingStarted (isSeeking: false)
09-29 20:36:58.978 i: [Player][Timeline] Playback started (or buffering), scheduling updates
09-29 20:36:58.978 w: [Player][Timeline] player position was negative. Position time will be reported as 0.
09-29 20:36:58.979 i: [PlaybackTimeBehaviour] Time: 51 IsStarted: true
09-29 20:36:58.992 i: [Treble]: Cache: READ returning EOF.
09-29 20:36:59.039 i: [Treble]: Cache: Ending network read thread.
09-29 20:36:59.044 i: [CurrentItemMetadataBehaviour] Fetched current item, success: true
09-29 20:36:59.045 i: [Treble]: BASS: Pausing stream 9954435 with fade, kill: 1
09-29 20:36:59.045 i: [Treble]: BASS: Ensuring next stream 9954436 is playing.
09-29 20:36:59.045 w: [Treble]: BASS: Stream didn't have a channel.
09-29 20:36:59.045 i: [Player][Treble] Queuing up next track: 9954437
09-29 20:36:59.045 i: [Treble]: BASS: Opening stream 9954436.
09-29 20:36:59.046 i: [Treble]: PQCache: Setting current item to 9954436.
09-29 20:36:59.046 w: [Treble]: Cache: Failed to read metadata from disk or version mismatch.
09-29 20:36:59.046 i: [Treble]: Cache: Opened cache file with 0 bytes (of 0 total) at '/data/user/0/com.plexapp.android/cache/Treble/Library/Caches/Media/a5447ad2b674009e1ef61a8cb451bfe38035e53d709edcfb292fcf6a0a59a415'.
09-29 20:36:59.046 i: [Treble]: Media: Found an item to direct play with bitrate under 2147483647 (it was 2653 kbps).
09-29 20:36:59.047 i: [Treble]: Cache: Opened cache file with 0 bytes (of 0 total) at '/data/user/0/com.plexapp.android/cache/Treble/Library/Caches/Media/a5447ad2b674009e1ef61a8cb451bfe38035e53d709edcfb292fcf6a0a59a415'.
09-29 20:36:59.047 i: [Treble]: Cache: Using RAM buffer of 3316 KB for item with container bitrate of 331 KB/sec.
09-29 20:36:59.047 i: [Treble]: Cache: Buffering until offset reaches 1694720 (read buffer offset: 0, size: 1694720).
09-29 20:36:59.047 i: [Treble]: Cache: Opened file: https://plex.*****.com:443/library/parts/185306/1632751930/file.flac?download=1&X-Plex-Client-Identifier=b36985684de1507d-com-plexapp-android&X-Plex-Device=ONEPLUS%20A6003&X-Plex-Device-Name=ONEPLUS%20A6003&X-Plex-Platform=Android&X-Plex-Platform-Version=11&X-Plex-Product=Plex%20for%20Android%20(Mobile)&X-Plex-Token=...J9Na&X-Plex-Version=8%2E23%2E1%2E28053
09-29 20:36:59.048 i: [Treble]: Cache: Kicking off buffering thread at offset 0, disk cache has 0 / 0.
09-29 20:36:59.048 i: [Treble]: Cache: Buffering to disk from offset 0.
09-29 20:36:59.048 i: Fetching [method:GET] https://plex.*****.com:443/:/timeline?bufferedTime=0&duration=492000&guid=plex%3A%2F%2Ftrack%2F5d07cd92403c640290f1bcb3&key=%2Flibrary%2Fmetadata%2F182386&playbackTime=51&playQueueItemID=9954436&ratingKey=182386&state=buffering&time=0&token=...J9Na&X-Plex-Client-Identifier=b36985684de1507d-com-plexapp-android&X-Plex-Token=...J9Na&X-Plex-Language=fr-fr
09-29 20:36:59.057 i: Fetching [method:GET] http://127.0.0.1:32500/media/providers/1/library/metadata/182473?includeLoudnessRamps=1&X-Plex-Language=fr-fr
09-29 20:36:59.060 i: [PlayQueueAPIHelperBase] Result container=<MediaContainer mediaTagPrefix="/system/bundle/media/flags/" identifier="com.plexapp.plugins.library" playQueueVersion="1" playQueueID="3402" size="22" playQueueSourceURI="library://x/directory/%2Flibrary%2Fsections%2F5%2Fall%3FincludeCollections%3D1%26sort%3DtitleSort%26sourceType%3D8" playQueueShuffled="1" playQueueSelectedItemID="9954435" playQueueSelectedMetadataItemID="181708" playQueueTotalCount="979" mediaTagVersion="1631637217" playQueueSelectedItemOffset="0" />
09-29 20:36:59.061 i: [HttpServer] /127.0.0.1:38786 - GET /media/providers/1/library/metadata/182473
09-29 20:36:59.072 i: Fetching [method:GET] https://plex.*****.com:443/:/timeline?bufferedTime=0&duration=492000&guid=plex%3A%2F%2Ftrack%2F5d07cd92403c640290f1bcb3&key=%2Flibrary%2Fmetadata%2F182386&playbackTime=51&playQueueItemID=9954436&ratingKey=182386&state=buffering&time=0&token=...J9Na&X-Plex-Client-Identifier=b36985684de1507d-com-plexapp-android&X-Plex-Token=...J9Na&X-Plex-Language=fr-fr
09-29 20:36:59.073 e: Error fetching http://127.0.0.1:32500/media/providers/1/library/metadata/182473?includeLoudnessRamps=1:
<html><head><title>Not Found</title></head><body><h1>404 Not Found</h1></body></html>
09-29 20:36:59.073 i: [Treble]: PQCache: Set item 9954437 active to 1, 2 active remaining.
09-29 20:36:59.073 i: [Treble]: RAMP: End ramp length: 11.33 Start ramp length: 0.14 Total overlap: 11.47.
09-29 20:36:59.074 i: [Treble]: BASS: Queueing stream (2 total, 4 handles) with identifier 9954437, gain nan dB, overlap duration 11468 ms, start offset 0 ms (paused: 1).
09-29 20:36:59.074 i: [Player][Treble] Finished queing item 9954437.
09-29 20:36:59.074 i: [Player][Treble] Audio Queue Now: 9954436-9954437
09-29 20:36:59.078 i: [MediaSessionBehaviour] Updating metadata for music, thumb: true
09-29 20:36:59.095 i: Fetching [method:GET] https://plex.*****.com:443/:/timeline?bufferedTime=0&duration=492000&guid=plex%3A%2F%2Ftrack%2F5d07cd92403c640290f1bcb3&key=%2Flibrary%2Fmetadata%2F182386&playbackTime=51&playQueueItemID=9954436&ratingKey=182386&state=buffering&time=0&token=...J9Na&X-Plex-Client-Identifier=b36985684de1507d-com-plexapp-android&X-Plex-Token=...J9Na&X-Plex-Language=fr-fr
09-29 20:36:59.115 w: [MetricsSender] Error posting metrics. Response error code: 400
09-29 20:36:59.297 i: [Treble]: BASS: Stream 9954435 has been faded out and now we'll kill it.
09-29 20:36:59.297 i: [Treble]: BASS: Getting rid of stream 9954435.
09-29 20:36:59.297 i: [Treble]: BASS: Closing stream 9954435.
09-29 20:36:59.297 i: [Treble]: BASS: Deleting gapless stream 0x80000043.
09-29 20:36:59.298 i: [Treble]: PQCache: Set item 9954435 active to 0, 2 active remaining.
09-29 20:36:59.298 i: [Treble]: Cache: Deleting file reader 0x7840a13b68 (1 live)
09-29 20:36:59.696 i: [Treble]: Cache: HTTP response code was 200.
09-29 20:36:59.697 i: [Treble]: Cache: HTTP response total size was 163329200.
09-29 20:36:59.802 i: [Treble]: Cache: Asked to seek to offset 163329057 with read buffer offset at 262144.
09-29 20:36:59.803 i: [Treble]: Cache: Failing a seek to the end.
09-29 20:36:59.804 i: [Treble]: Cache: Asked to seek to offset 163329190 with read buffer offset at 262144.
09-29 20:36:59.804 i: [Treble]: Cache: Failing a seek to the end.
09-29 20:36:59.807 i: [Treble]: Cache: Asked to seek to offset 11539 with read buffer offset at 278528.
09-29 20:36:59.807 i: [Treble]: Cache: Yay, seek was inside read buffer.
09-29 20:36:59.807 i: [Treble]: Cache: Buffering until offset reaches 1706259 (read buffer offset: 11539, size: 1694720).
09-29 20:36:59.808 i: [Treble]: BASS: Stream 9954436 (channel 0x00000000) changed buffering state to 1.
09-29 20:36:59.809 i: [Treble]: Cache: Asked to seek to offset 13436 with read buffer offset at 278528.
09-29 20:36:59.809 i: [Treble]: Cache: Yay, seek was inside read buffer.
09-29 20:36:59.810 i: [Treble]: Cache: Buffering until offset reaches 1708156 (read buffer offset: 13436, size: 1694720).
09-29 20:36:59.811 i: [Treble]: Cache: Asked to seek to offset 13459 with read buffer offset at 278528.
09-29 20:36:59.812 i: [Treble]: Cache: Yay, seek was inside read buffer.
09-29 20:36:59.812 i: [Treble]: Cache: Buffering until offset reaches 1708179 (read buffer offset: 13459, size: 1694720).
09-29 20:36:59.816 i: [Treble]: Cache: Asked to seek to offset 0 with read buffer offset at 262144.
09-29 20:36:59.817 i: [Treble]: Cache: Yay, seek was inside read buffer.
09-29 20:36:59.818 i: [Treble]: Cache: Buffering until offset reaches 1694720 (read buffer offset: 0, size: 1694720).
09-29 20:36:59.819 i: [Treble]: BASS: Opened stream 9954436 in 772 ms (paused: 0) with gain nan dB, max 2147483647 Kbps (picked flac, 2653 Kbps, actual 2652 Kbps/sec).
09-29 20:36:59.820 i: [Treble]: BASS: Created a gapless source stream for 9954436 (channel: 0x8000004b) with sample rate of 88200 and 2 channels (paused: 1)
09-29 20:36:59.820 i: [Treble]: BASS: Reading first bytes to ensure stream 9954436 is warmed up.
09-29 20:36:59.821 i: [Treble]: Cache: Asked to seek to offset 8282 with read buffer offset at 278528.
09-29 20:36:59.821 i: [Treble]: Cache: Yay, seek was inside read buffer.
09-29 20:36:59.822 i: [Treble]: Cache: Buffering until offset reaches 1703002 (read buffer offset: 8282, size: 1694720).
09-29 20:36:59.921 i: [Treble]: Cache: Buffering complete as offset is now greater than 1703002 (1744896) and read completed: 0.
09-29 20:36:59.921 i: [Treble]: BASS: Stream 9954436 (channel 0x8000004b) changed buffering state to 0.
09-29 20:36:59.922 i: [EngineEventManager] onBufferingEnded
09-29 20:36:59.922 i: [EngineEventManager] onPlaybackResumed
09-29 20:36:59.922 w: [Player][Timeline] player position was negative. Position time will be reported as 0.
09-29 20:36:59.924 i: [PlaybackTimeBehaviour] Time: 995 IsStarted: true
09-29 20:36:59.924 i: [PlaybackTimeBehaviour] Resuming stopwatch
09-29 20:36:59.924 i: [AudioFocusBehaviour] Playback resumed
09-29 20:36:59.924 i: [PlayQueueProgressBehaviour] Updating PlayQueueManager state, isPlaying: true
09-29 20:36:59.924 i: Fetching [method:GET] https://plex.*****.com:443/:/timeline?bufferedTime=5490&duration=492000&guid=plex%3A%2F%2Ftrack%2F5d07cd92403c640290f1bcb3&key=%2Flibrary%2Fmetadata%2F182386&playbackTime=996&playQueueItemID=9954436&ratingKey=182386&state=playing&time=0&token=...J9Na&X-Plex-Client-Identifier=b36985684de1507d-com-plexapp-android&X-Plex-Token=...J9Na&X-Plex-Language=fr-fr
09-29 20:36:59.927 i: [WiFiLockBehaviour] Aquiring WiFi lock since playback was resumed.
09-29 20:36:59.938 i: [MediaSessionBehaviour] Updating state to PLAYING
09-29 20:37:00.060 i: [Treble]: Cache: Network buffer is now ahead of read buffer, which has 3395584 bytes. Godspeed.
09-29 20:37:00.142 i: [Treble]: Cache: Network error (-23) occurred, we might want to kick off recovery (still 262144 bytes in network buffer).
09-29 20:37:00.292 w: [Treble]: Connection Tester: Failure (22, HTTP code 400) for http://5.***.***.51:443
09-29 20:37:00.310 w: [Treble]: Connection Tester: Failure (22, HTTP code 400) for http://plex.*****.com:443
09-29 20:37:00.331 w: [Treble]: Connection Tester: Failure (60, HTTP code 0) for https://5-9-148-51.dbfa32749abc44688f86ef699bfa1c23.plex.direct:443
09-29 20:37:00.360 i: [UserAction] Select menu item: Up.
09-29 20:37:00.362 e: [Treble]: Cache: The connection test failed, so we're marking the stream as errored.
09-29 20:37:00.525 i: [Player][Timeline] Handling player error
09-29 20:37:00.526 i: [Player][Timeline] Playback stopped (error: true)
09-29 20:37:00.526 w: [Player][Timeline] player position was negative. Position time will be reported as 0.
09-29 20:37:00.527 i: [PlaybackTimeBehaviour] Time: 1599 IsStarted: true
09-29 20:37:00.527 i: [EngineEventManager] onPlaybackStopped: Completed
09-29 20:37:00.527 i: [Player][Timeline] Playback stopped (error: false)
09-29 20:37:00.527 w: [Player][Timeline] player position was negative. Position time will be reported as 0.
09-29 20:37:00.527 i: Fetching [method:GET] https://plex.*****.com:443/:/timeline?bufferedTime=20185&duration=492000&guid=plex%3A%2F%2Ftrack%2F5d07cd92403c640290f1bcb3&key=%2Flibrary%2Fmetadata%2F182386&playbackTime=1599&playQueueItemID=9954436&ratingKey=182386&state=stopped&time=0&token=...J9Na&X-Plex-Client-Identifier=b36985684de1507d-com-plexapp-android&X-Plex-Token=...J9Na&X-Plex-Language=fr-fr
09-29 20:37:00.528 i: [PlaybackTimeBehaviour] Time: 1600 IsStarted: true
09-29 20:37:00.532 i: [PlaybackTimeBehaviour] Playback stopped, pausing stopwatch
09-29 20:37:00.532 i: [PlaybackTimeBehaviour] Time: 1604 IsStarted: false
09-29 20:37:00.532 i: [PlayQueueProgressBehaviour] Updating PlayQueueManager state, isPlaying: false
09-29 20:37:00.533 i: [EngineEventManager] onPlaybackStarted: 9954437
09-29 20:37:00.533 i: [Player][Timeline] Playback started (or buffering), scheduling updates
09-29 20:37:00.533 w: [Player][Timeline] player position was negative. Position time will be reported as 0.
09-29 20:37:00.534 i: [PlaybackTimeBehaviour] Time: 1604 IsStarted: false
09-29 20:37:00.537 i: [PlaybackTimeBehaviour] Initialising
09-29 20:37:00.537 i: [PlaybackTimeBehaviour] Starting stopwatch
09-29 20:37:00.538 i: [AudioFocusBehaviour] Playback started
09-29 20:37:00.538 i: [PlayQueueProgressBehaviour] Updating PlayQueueManager state, isPlaying: true
09-29 20:37:00.538 i: [PlayQueueBehaviour] Clearing video PQ because audio playback has started.
09-29 20:37:00.548 i: [WiFiLockBehaviour] Aquiring WiFi lock since playback was started.
09-29 20:37:00.550 i: Fetching [method:GET] https://plex.*****.com:443/:/timeline?bufferedTime=20185&duration=492000&guid=plex%3A%2F%2Ftrack%2F5d07cdba403c640290f576fa&key=%2Flibrary%2Fmetadata%2F182473&playbackTime=1604&playQueueItemID=9954437&ratingKey=182473&state=playing&time=0&token=...J9Na&X-Plex-Client-Identifier=b36985684de1507d-com-plexapp-android&X-Plex-Token=...J9Na&X-Plex-Language=fr-fr
09-29 20:37:00.551 i: [BatteryMonitorBehaviour] Starting playback with 2081131 µAh (56%).
09-29 20:37:00.556 i: [MediaSessionBehaviour] Updating state to PLAYING
09-29 20:37:00.556 i: [Player] onPlaybackStarted
09-29 20:37:00.556 i: [Treble]: BASS: Resume.
09-29 20:37:00.557 i: [PlayQueueProgressBehaviour] Item completed, moving to next PlayQueue item
09-29 20:37:00.557 i: [PlayQueueAPIHelperBase] Retrieving play queue (id: 3402, repeat: 0).
09-29 20:37:00.557 i: Fetching [method:GET] https://plex.*****.com:443/playQueues/3402?center=9954437&includeLoudnessRamps=1&repeat=0&X-Plex-Token=...J9Na&X-Plex-Language=fr-fr
09-29 20:37:00.559 i: [Player][Treble] Removing already played track: 9954436
09-29 20:37:00.560 i: [Treble]: BASS: Asked to remove stream with identifier 9954436 with 2 existing streams (fade: 1, kickOffNext: 1).
09-29 20:37:00.560 i: [Treble]: PQCache: Set item 9954436 active to 0, 1 active remaining.
09-29 20:37:00.560 i: [Treble]: BASS: Removed stream 9954436 from position 0, there are now 1 streams.
09-29 20:37:00.560 i: [Treble]: Cache: Asked to close file.
09-29 20:37:00.560 i: [WiFiLockBehaviour] Releasing WiFi lock since playback was stopped.
09-29 20:37:00.561 w: [Player][Timeline] player position was negative. Position time will be reported as 0.
09-29 20:37:00.561 i: [BatteryMonitorBehaviour] Playback session was 0,0 minutes long.
09-29 20:37:00.561 i: [BatteryMonitorBehaviour] Average battery consumption was 0,00 µAh per minute.
09-29 20:37:00.562 i: [MediaSessionBehaviour] Updating state to STOPPED
09-29 20:37:00.563 i: [MediaSessionBehaviour] Releasing MediaSessionHelper
09-29 20:37:00.564 i: [MediaSessionHelper] Releasing media session with tag: music
09-29 20:37:00.567 i: [PlaybackTimeBehaviour] Time: 29 IsStarted: true
09-29 20:37:00.567 w: [Player][Timeline] Ignoring timeline update, as less than 8 seconds has passed since last update without any state change.
09-29 20:37:00.568 i: [Player][Treble] onRuntimeSessionOptionsChanged
09-29 20:37:00.569 i: Fetching [method:GET] https://plex.*****.com:443/library/streams/287142/levels?subsample=256&X-Plex-Token=...J9Na&X-Plex-Language=fr-fr
09-29 20:37:00.570 i: [MediaSessionHelper] Starting media session with tag: music
09-29 20:37:00.570 i: [MediaSessionHelper] Creating media session with tag: music
09-29 20:37:00.575 i: [Treble]: Cache: Ending network read thread.
09-29 20:37:00.577 i: [Treble]: BASS: Pausing stream 9954436 with fade, kill: 1
09-29 20:37:00.578 i: [Treble]: BASS: Ensuring next stream 9954437 is playing.
09-29 20:37:00.578 w: [Treble]: BASS: Stream didn't have a channel.
09-29 20:37:00.579 i: Fetching [method:GET] https://plex.*****.com:443/:/timeline?bufferedTime=0&duration=492000&guid=plex%3A%2F%2Ftrack%2F5d07cdba403c640290f576fa&key=%2Flibrary%2Fmetadata%2F182473&playbackTime=29&playQueueItemID=9954437&ratingKey=182473&state=playing&time=0&token=...J9Na&X-Plex-Client-Identifier=b36985684de1507d-com-plexapp-android&X-Plex-Token=...J9Na&X-Plex-Language=fr-fr
09-29 20:37:00.579 i: [Player][Treble] Queuing up next track: 9954438
09-29 20:37:00.579 i: [Treble]: BASS: Opening stream 9954437.
09-29 20:37:00.580 i: [Treble]: PQCache: Setting current item to 9954437.
09-29 20:37:00.580 w: [Treble]: Cache: Failed to read metadata from disk or version mismatch.
09-29 20:37:00.580 i: [Treble]: Cache: Opened cache file with 0 bytes (of 0 total) at '/data/user/0/com.plexapp.android/cache/Treble/Library/Caches/Media/f0cbbc7430f93569a708351e4512a650cf6e47427eaf213ea14c4c273be65b6b'.
09-29 20:37:00.581 i: [Treble]: Media: Found an item to direct play with bitrate under 2147483647 (it was 917 kbps).
09-29 20:37:00.581 w: [Treble]: Cache: Failed to read metadata from disk or version mismatch.
09-29 20:37:00.582 i: [Treble]: Cache: Opened cache file with 0 bytes (of 0 total) at '/data/user/0/com.plexapp.android/cache/Treble/Library/Caches/Media/f0cbbc7430f93569a708351e4512a650cf6e47427eaf213ea14c4c273be65b6b'.
09-29 20:37:00.583 i: [Player][Timeline] Player error not known by server, reporting original player error (or a playback interrupted one)
09-29 20:37:00.583 i: [Player] Error reported: TransientError (null)
09-29 20:37:00.583 i: [Player][Timeline] Playback stopped (error: false)
09-29 20:37:00.584 w: [Player][Timeline] player position was negative. Position time will be reported as 0.
09-29 20:37:00.584 i: [PlaybackTimeBehaviour] Time: 45 IsStarted: true
09-29 20:37:00.584 i: [Treble]: Cache: Using RAM buffer of 2048 KB for item with container bitrate of 114 KB/sec.
09-29 20:37:00.590 i: Showing toast: Une erreur s'est produite pendant la lecture de ce fichier.
09-29 20:37:00.591 i: [Treble]: Cache: Buffering until offset reaches 583680 (read buffer offset: 0, size: 583680).
09-29 20:37:00.591 i: [Treble]: Cache: Opened file: https://plex.*****.com:443/library/parts/185381/1632751828/file.flac?download=1&X-Plex-Client-Identifier=b36985684de1507d-com-plexapp-android&X-Plex-Device=ONEPLUS%20A6003&X-Plex-Device-Name=ONEPLUS%20A6003&X-Plex-Platform=Android&X-Plex-Platform-Version=11&X-Plex-Product=Plex%20for%20Android%20(Mobile)&X-Plex-Token=...J9Na&X-Plex-Version=8%2E23%2E1%2E28053
09-29 20:37:00.593 i: [CurrentItemMetadataBehaviour] Fetching current item
09-29 20:37:00.593 i: Fetching [method:GET] https://plex.*****.com:443/library/metadata/182473?includeChapters=1&includeLoudnessRamps=1&includeMarkers=1&includeRelated=1&X-Plex-Token=...J9Na&X-Plex-Language=fr-fr
09-29 20:37:00.594 i: [EngineEventManager] onBufferingStarted (isSeeking: false)
09-29 20:37:00.595 i: [Player][Timeline] Playback started (or buffering), scheduling updates
