Android Update, Trailers on Homepage
Android Client 9.12.2.36964 (054b7995) uodate has broke. The ability to watch trailers on the Home Page. Anyone aware of this.
Ok…so if you click a certain trailer from the home page, it says it says it is unavailble. You have to click the trending trailers headinf first, then select a trailee. Not sure if this is how the developers were going for it to work, but if so, may want to remove the error you get when you first select a trailer because it gives the impression it is broke.
Just posting that devs are aware and looking into this
