AniDB [Custom Scanner]
Hey,
I thought I'd share, I've been having some issues getting my Anime collection to show up (still do, it's huge and it crashes PMS but that asside)
I've been using adbren.pl to rename my files, using profile 4. I had some problems with them being picked up correctly.
So I wrote a small scanner my self that will correctly parse them and try to fill in the Show, Episode Nr and Title.
It will ignore the ED and OP files and also the specials, although I may fix this in the future.
Hopefully it is useful for someone :3
AniDB [Profile 4].py
# Copyright (c) 2013 Jorge Schrauwen. All rights reserved.
# AniDB Is a scanner that will parse files renamed using adbren.pl using the following format:
# %anime_name_romaji% - %episode% - %episode_name% - [%group_short%](%crc32%).%filetype%
import re, os, os.path
import Media, VideoFiles, Stack, Utils
parse episode number
def parseEpisode(ep, season=1):
  try:
    int(ep)
    return [[season, int(ep)]]
  except ValueError:
    if season > 0:
      if ep[0:1].upper() == ‘S’:
        return parseEpisode(ep[1:], 0)
      else:
        if ep.find(’-’) > 0:
          mep = ep.split(’-’)
          mepr =
          try:
            for ep in range(int(mep[0]), (int(mep[1]) + 1)):
              mepr.append([season, int(ep)])
          except:
            pass
          finally:
            if len(mepr) > 0:
              return mepr
            else:
              return None
    else:
      return None
Scans through files, and add to the media list.
def Scan(path, files, mediaList, subdirs, language=None, root=None):
  # Just look for video files.
  VideoFiles.Scan(path, files, mediaList, subdirs, root)
  # Add them all.
  for path in files:
    (show, year) = VideoFiles.CleanName(os.path.basename(path))
    file = Utils.SplitPath(path)[-1]
    ext = file.split(’.’)[-1]
    name = ‘.’.join(file.split(’.’)[0:-1])
    nameChunks = name.split(’ - ')
    # correct for “-” in show name or title
    if len(nameChunks) > 4:
      if parseEpisode(nameChunks[1]) == None:
        if len(nameChunks[1]) >= 4:
          if parseEpisode(nameChunks[2]) <> None:
            extra = nameChunks.pop(1)
            nameChunks[0] = “%s - %s” % (nameChunks[0], extra)
      else:
        while len(nameChunks) > 4:
          extra = nameChunks.pop(3)
          nameChunks[2] = “%s - %s” % (nameChunks[2], extra)
    try:
      sep = parseEpisode(nameChunks[1])
      if sep <> None:
        if len(sep) == 1:
          anime_ep = Media.Episode(nameChunks[0], sep[0][0], sep[0][1], nameChunks[2])
          anime_ep.parts.append(path)
          mediaList.append(anime_ep)
        else:
          for ep in sep:
            beginEp = sep[0][1]
            endEp = sep[-1][1]
            anime_ep = Media.Episode(nameChunks[0], ep[0], ep[1], nameChunks[2])
            anime_ep.display_offset = (ep[1]-beginEp)*100/(endEp-beginEp+1)
    except:
      with open(’/tmp/adb-unmatchables.log’, ‘a’) as log:
        log.write("%s
" % file)
Update to handle multi epside files and fixed some crashes.
Hi there!
May you give me a hind about how to install it to the PMS?
Hi there!
Sorry for the late reply, I didn't get a notifcation...
How to install a custom scanner is explained here: https://forums.plex.tv/topic/19396-how-to-install-a-custom-scanner/
