Another issue
Today I turned the TV on and was going to stream TV shows that I recorded yesterday. But Plex would not connect to the Plex media server. I ended up rebooting the Linux PC. Then I tried to retry connection and t would not connect. I then exited Plex and restarted Plex and it worked this time. This is the second time this has happened.
These lines were for a show that I recorded and watched. I didn’t see anything wrong with the show
Apr 10, 2025 19:59:02.619 [17736] ERROR - [Grabber/67ac16038c259427c70b6339076e321a59b90459] Unable to find title for item of type 5
Apr 10, 2025 19:59:12.749 [17736] ERROR - [Grabber/67ac16038c259427c70b6339076e321a59b90459] Unable to find title for item of type 5
Apr 10, 2025 19:59:12.750 [17736] ERROR - [Grabber/67ac16038c259427c70b6339076e321a59b90459] Unable to find title for item of type 5
Apr 10, 2025 19:59:17.975 [17788] INFO - [Grabber/67ac16038c259427c70b6339076e321a59b90459] Notification: Recording Georgie & Mandy’s First Marriage - E16 - Baby Fight -
Apr 10, 2025 20:32:00.543 [4924] WARN - [Grabber/67ac16038c259427c70b6339076e321a59b90459] MDE: unable to find a working transcode profile for video stream
Apr 10, 2025 20:32:00.749 [16440] ERROR - [Grabber/67ac16038c259427c70b6339076e321a59b90459/CreditsDetectionManager/Response::fetch/MarkerResponse] incomplete marker attributes
Apr 10, 2025 20:32:35.000 [17260] ERROR - [Grabber/67ac16038c259427c70b6339076e321a59b90459/CreditsDetectionManager] PeekNamedPipe failed: 0x6d
Apr 10, 2025 20:32:35.000 [17260] ERROR - [Grabber/67ac16038c259427c70b6339076e321a59b90459/CreditsDetectionManager] BufferingLineReader: failed to read line (error: -1)
Apr 11, 2025 18:03:31.027 [17860] ERROR - [Grabber/67ac16038c259427c70b6339076e321a59b90459] Transcoder: Failed to delete session directory (boost::filesystem::remove_all: The process cannot access the file because it is being used by another process [system:32]: “C:\Users\rac80\AppData\Local\Plex Media Server\Cache\Transcode\Sessions\plex-transcode-nzkdzh28pusdcxruwmrj0bc2-c2950317-ccf1-432f-b292-97ef078e4b9a”)
Apr 10, 2025 20:02:17.700 [2944] INFO - [Req#207b2/Transcode] [FFMPEG] - MFT name: ‘Microsoft AAC Audio Encoder MFT’
I have a log that is 4000 lines with 3000 errors. Yet It seems to record tv shows I think.
It is hard to know if a show didn’t record until I try to watch them an notice it is missing.
Apr 10, 2025 19:59:10.879 [17628] ERROR - [Req#1ed86/Transcode/79e385ee-1a65-4f02-ab86-30aca6043adb/3e044d3b-0ffe-4b84-ac99-c73a9b146875] [mpeg2video @ 0000020eb297fb80] Invalid frame dimensions 0x0.
I’m just trying to record TV. Which seems to be working.
