Thank you.
I see some serious stuff going on. I now fully understand why youâre upset.
Determines what to do (transcode); expect transcoder to start (not shown due to logging setting ? ), PMS attempts to play the first block of the file and gets â404â (Not found)
Jun 28, 2021 18:17:12.812 [0x7fc5effff700] DEBUG - Auth: authenticated user 1 as armyofquad
Jun 28, 2021 18:17:12.818 [0x7fc5effff700] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jun 28, 2021 18:17:12.819 [0x7fc5effff700] DEBUG - Selecting best audio stream for part ID 76719 (autoselect: 0 language: en)
Jun 28, 2021 18:17:12.819 [0x7fc5effff700] DEBUG - Audio Stream: 153836, Subtitle Stream: -1
Jun 28, 2021 18:17:12.820 [0x7fc5effff700] DEBUG - MDE: Selected protocol hls; container: mkv
Jun 28, 2021 18:17:12.820 [0x7fc5effff700] DEBUG - MDE: analyzing media item 75681
Jun 28, 2021 18:17:12.820 [0x7fc5effff700] DEBUG - MDE: E2 - We Can't Help It, We're Men: Direct Play is disabled
Jun 28, 2021 18:17:12.820 [0x7fc5effff700] DEBUG - MDE: E2 - We Can't Help It, We're Men: media must be transcoded in order to use the hls protocol
Jun 28, 2021 18:17:12.820 [0x7fc5effff700] DEBUG - MDE: E2 - We Can't Help It, We're Men: no direct play video profile exists for http/mkv/mpeg2video
Jun 28, 2021 18:17:12.820 [0x7fc5effff700] DEBUG - MDE: E2 - We Can't Help It, We're Men: no direct play video profile exists for http/mkv/mpeg2video/ac3
Jun 28, 2021 18:17:12.820 [0x7fc5effff700] DEBUG - MDE: The Red Green Show - E2 - We Can't Help It, We're Men: selected media 0 / 75681
Jun 28, 2021 18:17:12.820 [0x7fc5effff700] DEBUG - Streaming Resource: Reached Decision id=79987 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=75681 part=(id=76719 decision=transcode container=mkv protocol=hls streams=(Video=(id=153835 decision=copy width=720 height=480) Audio=(id=153836 decision=copy channels=2 rate=48000))))
Jun 28, 2021 18:17:12.822 [0x7fc66ffff700] DEBUG - Completed: [192.168.0.192:41430] 200 GET /video/:/transcode/universal/decision?audioBoost=100&autoAdjustQuality=0&directPlay=0&directStream=1&directStreamAudio=1&fastSeek=1&hasMDE=1&location=lan&maxVideoBitrate=200000&mediaBufferSize=209664&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F79987&protocol=*&session=25cb46cb78f9c9a7-com-plexapp-android&subtitleSize=100&videoBitrate=200000&videoQuality=100&videoResolution=3840x2160 (13 live) TLS GZIP 11ms 1405 bytes (pipelined: 16)
Jun 28, 2021 18:17:20.339 [0x7fc66ffff700] DEBUG - Auth: authenticated user 1 as armyofquad
What I also see â
Jun 28, 2021 18:17:27.090 [0x7fc66f7fe700] DEBUG - WebSocket: client initiated close
Jun 28, 2021 18:17:27.091 [0x7fc66ffff700] DEBUG - NotificationStream: Removing because of close
Jun 28, 2021 18:17:27.093 [0x7fc66f7fe700] DEBUG - handleStreamRead code 2: End of file
Jun 28, 2021 18:17:27.093 [0x7fc66f7fe700] DEBUG - Completed after connection close: [192.168.0.192:41411] -3 GET /:/websockets/notifications (13 live) TLS GZIP 41158ms 2194 byte
Which player were you using?
About your installation â
Where is /config ? Local drive or network mount ?
Where is the transcoder temporary directory ? /dev/shm, local drive, or network mount ?
