Any plugins to block media from certain online sources?
I dont want to disable the feature but theres plenty of things I could care less to see and dont want to see. Is there a plugin or way to block certain things off the server so I can see what I want to see and not get alot of useless stuff crammed down me?
plugins are deprecated, no there isn’t any plugin that does that, nor will there likely to be one.
aside from all that, you are gonna have to explain and/or provide more details of what exactly you are talking about or trying to accomplish.
if you are talking about plex web shows/news/podcasts, you can disable them in your plex account.
if you are talking about some other online sources, then plex does not use any other online sources, other than for metadata, so your entire question doesn’t make any sense.
Im talking about the webshows, news and podcasts. Theres only a couple of them I want to see and alot I really dont want to see. Id love to be able to watch what I want and not whats being forced to see. Theres a lot of “sources” of content I dont agree with at all.
ah I see.
as far as I know, there isn’t anything like that.
I don’t use those services, so can’t really say.
I would suggest you might create a new thread in the feature requests section, requesting some way to block or filter specific shows/news/podcasts.
In Podcasts and Web Shows, you can add items that you want to “My Podcasts/Webshows.”
Then select the “My Podcasts/Webshows” tab.
Assuming the “Remember selected tab” option is enabled in your settings, Plex will always land on the ‘My Podcasts’ tab when you go to Podcasts, and all you’ll see are the ones you chose.
Why that’s not available in News, I don’t know.
