We have multiple libraries setup - one for regular movies, and one for discreet movies (ahem). I want a way to open the Plex app without images of bits and pieces showing up on the dashboard. Is there a way to do this because I can’t find anything in any of the settings that seem to indicate that you can. I have already removed the discreet folder from showing up on the on-screen list but that didn’t help at all.
Additional information can be found here.
Where is this screen? I’m running Windows and there is no screen labeled “Edit Library”. Do I access something other than app.plex.tv/desktop# ?
On the home screen hover over library name and you will see menu button show up to right of library name
Thanks very much. Anyone else who comes across this–after hovering, select the three dots at the right, select “Edit” to get the “Edit Library” screen above.
