The cookie that saves the login session needs to be reworked. For instance, if I login to plex.tv/ or then go to the web app https://app.plex.tv/, I have to then enter my 4 digit pin code. After I am logged in, if I go to the the server dashboard, on the same login session, I have to then enter my 4 digit pin again. This get annoying when I am already logged in, so it seems that there is either a different cookie for the dashboard than the app.plex.tv or they do not auth to see that you already authed with a pin. It would be nice to not have to login twice or more with the same pin when I already did.
What browser are you using? Do you have any extensions running?
I know this may not work for you if others use that computer but you can set it to auto login to which skips the PIN entry in the General settings of web app
