Apparent Bugcheck caused by Transcoder
Server Version#: 1.32.0.6973
Player Version#: N/A
Win 10 x64 Version 22H2 Build 109045.2913
Today was the second time in 2 days that a bugcheck associated with Plex Transcoder has occurred.
I have the Debug Log but do not see anyway to attach it.
Here is the winDbg output for the bugcheck:
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
nt!_WHEA_ERROR_RECORD structure that describes the error condition. Try !errrec Address of the nt!_WHEA_ERROR_RECORD structure to get more details.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: ffffc008d9fbe028, Address of the nt!_WHEA_ERROR_RECORD structure.
Arg3: 00000000b6000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000100153, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
KEY_VALUES_STRING: 1
Key  : Analysis.CPU.mSec
Value: 4811
Key  : Analysis.DebugAnalysisManager
Value: Create
Key  : Analysis.Elapsed.mSec
Value: 4854
Key  : Analysis.IO.Other.Mb
Value: 6
Key  : Analysis.IO.Read.Mb
Value: 0
Key  : Analysis.IO.Write.Mb
Value: 20
Key  : Analysis.Init.CPU.mSec
Value: 2124
Key  : Analysis.Init.Elapsed.mSec
Value: 24141
Key  : Analysis.Memory.CommitPeak.Mb
Value: 92
Key  : Bugcheck.Code.DumpHeader
Value: 0x124
Key  : Bugcheck.Code.KiBugCheckData
Value: 0x124
Key  : Bugcheck.Code.Register
Value: 0x124
Key  : WER.OS.Branch
Value: vb_release
Key  : WER.OS.Timestamp
Value: 2019-12-06T14:06:00Z
Key  : WER.OS.Version
Value: 10.0.19041.1
FILE_IN_CAB: MEMORY.DMP
BUGCHECK_CODE: 124
BUGCHECK_P1: 0
BUGCHECK_P2: ffffc008d9fbe028
BUGCHECK_P3: b6000000
BUGCHECK_P4: 100153
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
PROCESS_NAME: Plex Transcoder.exe
STACK_TEXT:
ffffa8802c686938 fffff8020fab785a : 0000000000000124 0000000000000000 ffffc008d9fbe028 00000000b6000000 : nt!KeBugCheckEx
ffffa8802c686940 fffff8020da815b0 : 0000000000000000 ffffc008d9fbe028 ffffc008d73f73a0 ffffc008d9fbe028 : nt!HalBugCheckSystem+0xca
ffffa8802c686980 fffff8020fbb9b3e : 0000000000000000 ffffa8802c686a29 ffffc008d9fbe028 ffffc008d73f73a0 : PSHED!PshedBugCheckSystem+0x10
ffffa8802c6869b0 fffff8020fab9181 : ffffc008d9f90070 ffffc008d9f90070 ffffc008d73f73f0 ffffc008d73f73a0 : nt!WheaReportHwError+0x46e
ffffa8802c686a90 fffff8020fab94f3 : 0000000000000003 ffffc008d73f73f0 ffffc008d73f73a0 0000000000000003 : nt!HalpMcaReportError+0xb1
ffffa8802c686c00 fffff8020fab93d0 : ffffc008d72b3e78 0000000000000001 ffffa8802c686e00 0000000000000000 : nt!HalpMceHandlerCore+0xef
ffffa8802c686c50 fffff8020fab8915 : ffffc008d72b3e78 ffffa8802c686ef0 0000000000000000 0000000000000000 : nt!HalpMceHandler+0xe0
ffffa8802c686c90 fffff8020fabb0d5 : ffffc008d72b3e78 0000000000000000 0000000000000000 0000000000000000 : nt!HalpHandleMachineCheck+0xe9
ffffa8802c686cc0 fffff8020fb10bf9 : 0000000000000000 0000000000000000 0000000000000000 0000000000000000 : nt!HalHandleMcheck+0x35
ffffa8802c686cf0 fffff8020fa0c8ba : 0000000000000000 0000000000000000 0000000000000000 0000000000000000 : nt!KiHandleMcheck+0x9
ffffa8802c686d20 fffff8020fa0c577 : 0000000000000000 0000000000000000 00000132db315a98 0000000000000000 : nt!KxMcheckAbort+0x7a
ffffa8802c686e60 00007ff84ce5cbe3 : 0000000000000000 0000000000000000 0000000000000000 0000000000000000 : nt!KiMcheckAbort+0x277
0000001b048ff620 0000000000000000 : 0000000000000000 0000000000000000 0000000000000000 0000000000000000 : 0x00007ff8`4ce5cbe3
MODULE_NAME: AuthenticAMD
IMAGE_NAME: AuthenticAMD.sys
STACK_COMMAND: .cxr; .ecxr ; kb
FAILURE_BUCKET_ID: 0x124_0_AuthenticAMD_PROCESSOR_CACHE_IMAGE_AuthenticAMD.sys
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {d6c4d869-cd29-1e48-0267-5766712959d2}
Hi there. I asked our expert to take a look and they say this is a kernel bug mostly in your AMD driver. Have you updated the driver recently? Do you get the same error in earlier PMS builds?
The current AMD graphics driver is version 31.0.14051.1000 and was installed on 4/23/2023.
Now that I have reason to examine the system log I see that bugcheck 0x0101 has been occurring since 4/25/2023. Another bugcheck, 0x0124, has also occurred multiple times between 2/23/2023 and 4/22/2023 but the MEMORY.DMP file is overwritten each time so there are only the details provided in Event Viewer available, such as:
(EventID Qualifiers=16384 )1001(/EventID)
(Version)0(/Version)
(Level)2(/Level)
(Task)0(/Task)
(Opcode)0(/Opcode)
(Keywords)0x80000000000000(/Keywords)
(TimeCreated SystemTime=2023-04-22T13:51:56.2848407Z /)
(EventRecordID)7738(/EventRecordID)
(Correlation /)
(Execution ProcessID=0 ThreadID=0 /)
(Channel)System(/Channel)
(Computer)Media-Server(/Computer)
(Security /)
(/System)
(EventData)
(Data Name="param1 ")0x00000124 (0x0000000000000000, 0xffffb205283ad028, 0x00000000b6000000, 0x0000000000100153)(/Data)
(Data Name="*Param2 ")C:\Windows\MEMORY.DMP(/Data)
(Data Name="param3 ")9c4e2588-c1b4-4773-8a14-7db08fa5470d(/Data)
(/EventData)
(/Event)
