Server Version#: 1.43.0.10492
Player Version#: 2026.1.0 (1537)
There are several areas of the UI where the mouse-clicks don’t work with the Apple Keyboard (and I would assume any pointer on the iPad). Easiest to repro is the About page, the back arrow is not clickable with a mouse but does respond to touch. Other areas that don’t respond as expected include:
Downloads page, doesn’t scroll if hovering over a downloaded item (only scrolls if mouse is over a blank space between items)
Downloads page, X button to close doesn’t respond to mouse click
I’m sure there are others, but can’t remember all the areas where I’ve run into this issue.
Player Version#: 2026.2.0 (1564)
iPadOS Version#: 26.2.1
Universal Control: Disabled
Confirming this is my experience also, tested on iPad Pro 13" M5 with Apple Magic Keyboard. Can reproduce 100% of the time with the three examples provided above, and can add that neither the X or Cast buttons at the top work when you open any show/movie.
Also confirming (through direct testing) what you have found, the following situations all yield the same outcome, that various screen elements can’t be clicked:
iPad with Magic Keyboard (with integrated trackpad)
iPad with Mouse connected by BlueTooth
iPad with Trackpad connected by Universal Control
iPad with Mouse connected by Universal Control
Same here - using an iPad Pro M4 13” with a Magic Keyboard. Several of the UI elements are unclickable with the trackpad, most notably the “X” in the top left which means that I often have to either quit and relaunch the app to navigate back to the main menu or use the touchscreen.
Hoping Plex team can look at this, it is 100% reproducible on all iPads with pointing devices, still no reply as noted or fix after 4 further point releases of the client.
