Hello!
I don’t know if this has always been a thing, but haven’t used Plex in a while and came back to the Apple TV 4K app and I’m noticing under the playback settings that all my audio tracks get re-encoded to AC3 (unless they are already AC3/EAC3 which seem to get direct-played). Is this normal? Was this always the case? I feel like it used to be that Plex decoded everything (even DTS-HD/Dolby TrueHD) to PCM and the Apple TV would then output that. Or is this a limitation if you’re not a Plex Pass subscriber? Do I need to subscribe to the Plex Pass to get full audio output options? How does it all work? The Plex audio help on the website don’t really seem to indicate anything in particular one way or the other.
I’ve also noticed that some episodes that are DTS sound a little weird when converted this way. For example, the volume in Plex on some episodes of Community are much lower (mainly the center channel) than in, say, Infuse for example (which direct plays all/most audio tracks).
Thank you for the help!
