Apple Tv - Hide Pin codes
I have kids and they can see my pin code as I type it on the screen. Can this be changed as my pin can be up up left left right down instead of numbers and it will only beep on screen when it detects a direction for the pin instead of showing it on the screen. Its impossible to use pin codes the way it is set up now. This should be a easy programming fix. I know this has been discussed in other forums and it does seem to be a problem with other people for years.
I suppose this is already covered in those two existing feature suggestions (one asking to use the keys of a remote, one asking to use a mobile Plex app). I suggest you comment/vote in those threads in order to help us avoid distracting or cannibalizing votes.
Unless I’m missing some unique aspect of your suggestion I’ll close this thread as a duplicate.
These other threads are old. 1 from 2018 and the other is from 2016. Time to renew. This is also a security issue as a lot of people use there same pin as there credit card info
That’s not how the feature suggestion forum is supposed to work.
No offense but that’d be rather stupid, wouldn’t it?
