Apple TV Plex app has unprotected PIN input - please fix!
Hey there, Plex is amazing, just have a quick feature suggestion that I don’t think has come up but it’s really silly if there isn’t already a workaround.
If you have managed users secured with a PIN, and you’re using the Apple TV Plex app, the pin is easily visible to anyone watching the screen. This is reasonably acceptable if you’re using a remote that doesn’t support it, but when I’m using my phone as remote, I can type the numbers and they should be appropriately hidden on the screen, but they are not, and they should be.
I guess I’m insinuating the solution here but the problem is that every time the Apple TV Plex app locks for any reason, I have to put in a PIN and this is strange and annoying with kids that really want to look, or that I have to scroll to the number instead of just typing it in. Seems like this can be a more streamlined interface.
Thanks for reading!
2 posts were merged into an existing topic: Samsung TV plex pass pin
