Server Version#: Latest on Plex pass (this is been going on for over a year though and I keep my server updated
Has anyone else noticed that the volume level in Apple TV Plex app is really low? I have two Apple TV 4K is in my home, one connected directly to the TV, the other connected to a TV but using optical from the TV to a sound bar.
On both of the set ups I have to almost to very often turn the volume to for Max and it’s still not loud enough. The type of content doesn’t seem to matter (I have 80+ TB so content is diverse)?
(trans coding or playing original doesn’t seem to matter either)
I I have made sure that reduce loud sounds is not enabled.
Does anyone else have this issue or know of a solution? I have search the form and there’s many other posts like this but they all seem to be a bit older and don’t have a clear solution
(Or is there another appletv app/player I can use other than the Plex app, that will still recognize my library’s and organization?
(Btw , other apps like Netflix or HBO on both TVs are plenty loud)
