Apps screen is larger than tv screen, can’t see edges on some apps, how to you fix this? Please
If there is no app setting (probably not), the issue is your TV.
Change the format to:
No Overscan
Full 100%
or
some other setting that will bring the app back under control.
Usually found among Zoom settings.
(the one you used to stretch 4:3 to 16:9 - most likely)
Just cast the screen that will help in reducing the image pexels on the screen.
