Apt-get upgrade plexmediaserver
Are the repos still being updated? I have been using apt-get upgrade plexmediaserver for a while now but, for some time now, 1.20.1.3252-a78fef9a9 seems to be the last version published this way, while 1.23.1.4528-c0513eb4c is on the website
For reference, the instructions that I originally used were from here: Enable repository updating for supported Linux server distributions
This is what I receive when I run the command:
$ sudo apt-get upgrade plexmediaserver
Reading package lists... Done
Building dependency tree
Reading state information... Done
plexmediaserver is already the newest version (1.20.1.3252-a78fef9a9).
Did you run apt-get update first?
Yes. It doesnt help. Here is a more complete output:
$ sudo apt-get update
Hit:1 http://us.archive.ubuntu.com/ubuntu focal InRelease
Get:2 http://us.archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB]
Get:3 http://us.archive.ubuntu.com/ubuntu focal-backports InRelease [101 kB]
Get:4 http://us.archive.ubuntu.com/ubuntu focal-security InRelease [109 kB]
Get:5 http://us.archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages [988 kB]
Get:6 http://us.archive.ubuntu.com/ubuntu focal-updates/main amd64 c-n-f Metadata [13.4 kB]
Get:7 http://us.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages [777 kB]
Fetched 2,102 kB in 1s (1,882 kB/s)
Calculating upgrade... Done
The following packages have been kept back:
  ubuntu-advantage-tools
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Here, I opened my Ubuntu 20.04.2 VM
You can see the normal system updates,
Then addition of the repository
Then, knowing I have a previously manual installed PMS, upgrade
root@ubuntu:/home/chuck# apt-get update
Hit:1 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:2 http://security.ubuntu.com/ubuntu focal-security InRelease
Hit:3 http://us.archive.ubuntu.com/ubuntu focal InRelease
Hit:4 http://us.archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:5 http://us.archive.ubuntu.com/ubuntu focal-backports InRelease
Ign:6 https://github.com/intel/compute-runtime focal InRelease
Err:7 https://github.com/intel/compute-runtime focal Release
  404  Not Found [IP: 140.82.114.4 443]
E: The repository 'https://github.com/intel/compute-runtime focal Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
root@ubuntu:/home/chuck# apt-get upgrade plexmediaserver
plexmediaserver is already the newest version (1.22.1.4275-48e10484b).
The following package was automatically installed and is no longer required:
  libllvm9
Use 'sudo apt autoremove' to remove it.
The following packages will be upgraded:
  python3-software-properties software-properties-common software-properties-gtk ubuntu-advantage-tools
4 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 873 kB of archives.
After this operation, 2,331 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://us.archive.ubuntu.com/ubuntu focal-updates/main amd64 ubuntu-advantage-tools amd64 27.0.2~20.04.1 [773 kB]
Get:2 http://us.archive.ubuntu.com/ubuntu focal-updates/main amd64 software-properties-common all 0.98.9.5 [10.6 kB]
Get:3 http://us.archive.ubuntu.com/ubuntu focal-updates/main amd64 software-properties-gtk all 0.98.9.5 [64.0 kB]
Get:4 http://us.archive.ubuntu.com/ubuntu focal-updates/main amd64 python3-software-properties all 0.98.9.5 [25.1 kB]
Fetched 873 kB in 0s (2,021 kB/s)
Preconfiguring packages ...
(Reading database ... 186321 files and directories currently installed.)
Preparing to unpack .../ubuntu-advantage-tools_27.0.2~20.04.1_amd64.deb ...
Unpacking ubuntu-advantage-tools (27.0.2~20.04.1) over (20.3) ...
Preparing to unpack .../software-properties-common_0.98.9.5_all.deb ...
Unpacking software-properties-common (0.98.9.5) over (0.98.9.4) ...
Preparing to unpack .../software-properties-gtk_0.98.9.5_all.deb ...
Unpacking software-properties-gtk (0.98.9.5) over (0.98.9.4) ...
Preparing to unpack .../python3-software-properties_0.98.9.5_all.deb ...
Unpacking python3-software-properties (0.98.9.5) over (0.98.9.4) ...
Setting up python3-software-properties (0.98.9.5) ...
Setting up ubuntu-advantage-tools (27.0.2~20.04.1) ...
Installing new version of config file /etc/ubuntu-advantage/uaclient.conf ...
Created symlink /etc/systemd/system/multi-user.target.wants/ua-reboot-cmds.service → /lib/systemd/system/ua-reboot-cmds.service.
Created symlink /etc/systemd/system/timers.target.wants/ua-messaging.timer → /lib/systemd/system/ua-messaging.timer.
Setting up software-properties-common (0.98.9.5) ...
Setting up software-properties-gtk (0.98.9.5) ...
Processing triggers for dbus (1.12.16-2ubuntu2.1) ...
Processing triggers for shared-mime-info (1.15-1) ...
Processing triggers for desktop-file-utils (0.24-1ubuntu3) ...
Processing triggers for mime-support (3.64ubuntu1) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for gnome-menus (3.36.0-1ubuntu1) ...
Processing triggers for libglib2.0-0:amd64 (2.64.6-1~ubuntu20.04.3) ...
Processing triggers for man-db (2.9.1-1) ...
root@ubuntu:/home/chuck# cd /etc/apt
root@ubuntu:/etc/apt# ls
apt.conf.d  auth.conf.d  preferences.d  sources.bak  sources.list  sources.list.d  sources.list.save  trusted.gpg  trusted.gpg.d
root@ubuntu:/etc/apt# echo deb https://downloads.plex.tv/repo/deb public main | sudo tee /etc/apt/sources.list.d/plexmediaserver.list
root@ubuntu:/etc/apt# curl https://downloads.plex.tv/plex-keys/PlexSign.key | sudo apt-key add -
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100  3072  100  3072    0     0  20897      0 --:--:-- --:--:-- --:--:-- 20897
OK
root@ubuntu:/etc/apt# apt-get update
Hit:2 http://us.archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:3 http://us.archive.ubuntu.com/ubuntu focal-backports InRelease
Hit:4 http://dl.google.com/linux/chrome/deb stable InRelease
Get:5 https://downloads.plex.tv/repo/deb public InRelease [6,685 B]
Hit:6 http://security.ubuntu.com/ubuntu focal-security InRelease
Ign:7 https://github.com/intel/compute-runtime focal InRelease
Err:8 https://github.com/intel/compute-runtime focal Release
  404  Not Found [IP: 140.82.113.4 443]
Get:9 https://downloads.plex.tv/repo/deb public/main amd64 Packages [1,772 B]
root@ubuntu:/etc/apt# apt-get upgrade
  libllvm9
  plexmediaserver
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 86.8 MB of archives.
After this operation, 1,988 kB of additional disk space will be used.
Get:1 https://downloads.plex.tv/repo/deb public/main amd64 plexmediaserver amd64 1.22.3.4523-d0ce30438 [86.8 MB]
Fetched 86.8 MB in 1s (61.6 MB/s)
(Reading database ... 186341 files and directories currently installed.)
Preparing to unpack .../plexmediaserver_1.22.3.4523-d0ce30438_amd64.deb ...
PlexMediaServer install: Pre-installation Validation.
PlexMediaServer install: Pre-installation Validation complete.
Unpacking plexmediaserver (1.22.3.4523-d0ce30438) over (1.22.1.4275-48e10484b) ...
Setting up plexmediaserver (1.22.3.4523-d0ce30438) ...
PlexMediaServer install: PlexMediaServer-1.22.3.4523-d0ce30438 - Installation starting.
PlexMediaServer install: Now installing based on:
PlexMediaServer install:   Installation Type:   Update
PlexMediaServer install:   Process Control:     systemd
PlexMediaServer install:   Plex User:           plex
PlexMediaServer install:   Plex Group:          plex
PlexMediaServer install:   Video Group:         render
PlexMediaServer install:   Metadata Dir:        /var/lib/plexmediaserver/Library/Application Support
PlexMediaServer install:   Temp Directory:      /tmp
PlexMediaServer install:   Lang Encoding:       en_US.UTF-8
PlexMediaServer install:   Intel QSV Hardware:  Not found
PlexMediaServer install:   Nvidia GPU card:     Not Found
PlexMediaServer install:   OpenCL library:      Not Installed
PlexMediaServer install:   Beignet package:     Not Installed
PlexMediaServer install: WARNING: Package 'Beignet', required for hardware transcoding of HDR content, is missing.
PlexMediaServer install:          Please install package:  'beignet-opencl-icd'
PlexMediaServer install: WARNING: The OpenCL library, required for hardware transcoding of HDR content, is missing.
PlexMediaServer install:          Please install package:  'ocl-icd-libopencl1'
PlexMediaServer install: Completing final configuration.
PlexMediaServer install: Starting Plex Media Server.
PlexMediaServer install: PlexMediaServer-1.22.3.4523-d0ce30438 - Installation successful.  Errors: 0, Warnings: 2
Processing triggers for libc-bin (2.31-0ubuntu9.2) ...
ugh. Well that there would be the problem. And yep, re-adding the repo fixed the problem.
Updated my scripts to prevent that particular problem from popping up again. And now to figure out why it disappeared in the first place…
Thanks for the help!
