Can someone please provide me the step by step instructions for upgrading PLEX media server on Ubuntu to the new versions?
Thanks for all who support me.
This will only work for public releases!
https://support.plex.tv/articles/235974187-enable-repository-updating-for-supported-linux-server-distributions/
See the Linux section in the server installation support article; this requires manual downloading the file and works for both, public and beta releases.
https://support.plex.tv/articles/200288586-installation/
There’s a few scripts flying around in the forum which help automate scenario 2.
At what exact step/command do you get that warning/error?
Did you execute both commands from the support article?
I did
echo deb https://downloads.plex.tv/repo/deb public main | sudo tee /etc/apt/sources.list.d/plexmediaserver.list
Then did sudo apt-get update
You forgot the 2nd command
curl https://downloads.plex.tv/plex-keys/PlexSign.key | sudo apt-key add -
before running
sudo apt-get update
Thank you it is up and running! ![]()
