Artifacts during video playback
Server Version#: Linux 1.25.1.5286
Player Version#: Web 4.71.0
I use plex on fedora 35 with Nvidia drivers 470.74 installed
since the previous server version I started getting artifacts while playing films, I usually use a Samsung TV but when artifacts began to appear, I could see them on the ps4-client and the web player also.
such problems occur on files 1080p h264, 4k h265…
previously these films were played without problems, they are also playable on a PC without problems …
what should I check/change to get rid of these problems?
@King555
That looks like the playback bitrate (as set by the player) is super low.
Can you check that please ?
I have a limit for watching through Internet 8mb, and no limit on a local network.
this problem appears periodically, maybe once every 5 minutes for 1-3 seconds, or it can repeat every 20 minutes …
@King555
When playing through the internet, we have a whole host of extra issues to worry about.
Looking at the entire list –
  1. Is the server connected with wire or wireless to the internet
  2. Is the player on the other end connected with wire or wireless ?
if wireless is involved – ALL the questions need to be asked.
  1. 2.4 Ghz or 5 Ghz?
  2. Amble bandwidth over the wireless (it’s not too congested and signal is strong enough) ?
Lastly, the video itself. Is it a good quality file or something of unknown and questionable origin ? (could be damaged in a way which only shows when transcoding)
All devices are located in one network and connected to a gigabit router through a wire.
Also 100 mb internet connection in WAN.
Video files have not been modified/replaced
These problems started to appear when I updated Plex-server from 1.24 to 1.25
I found my problem…
Broken RAM. I replaced one stick with a new one and now everything looks good
