Server Version#: 1.29.0.6244
Player Version#: all versions
When I have albums in my collection with BOTH a single artist (e.g. “Taylor Deupree”) and with multi-artist releases where an ampersand is used (e.g. “Taylor Deupree & Kenneth Kirschner”), I often find that the ampersand version of the artist name will take over ALL releases for the first artist (e.g. all “Taylor Deupree” releases are listed as “Taylor Deupree & Kenneth Kirschner”). Once this happens, there is no way to undo it. IF I rename the artist field of a specific album (e.g. “A&B” → “A”), the album disappears but then Plex immediately puts the artist field back to the original form. IF I rename the entire artist category, I now see “A” instead of “A&B”, but of course all of my “A&B” albums are now incorrect - this just reverses the problem.
Other observations:
- This doesn’t occur with ALL artist fields containing an ampersand - it MAY be related to the order things are added, e.g. if the “Someone & Someone Else” is added first, then it takes over all subsequent “Someone” releases.
- I haven’t yet seen this occur where artist names are separated by “and” rather than “&” - but it’s possible that this is just a coincidence, I notice that “&” is more common in my library.
- “Fix Match” and “Refresh Metadata” don’t seem to fix this.
- I have not tried the “Plex Dance”, but in any case this isn’t a viable solution - I have MANY artists that are affected, and anyway if it’s order dependent, then specifically re-adding each album in a specific order or workaround the bug would obviously be a nightmare…
- It LOOKS like “Split Apart” will fix this, but this ends up being a total disaster. If I have a “buggy” artist of the form “A&B” that contains albums by “A”, “A&B” and “A&C”, then splitting leaves me with THREE duplicate “A&B” artists, each containing the respective albums. At this point, I can probably manually rename each of these artists to what they should by, but this doesn’t happen automatically.
This is a bit of a nightmare, as I’ve slowly discovered that any artists in my library that collaborate tend to be munged into some unexpected bin based on, like, a single collaboration EP they released in 2001 ![]()
