Aspect ratio filter
I think the aspect ratio filter would be quite useful. I am able to filter my movies by resolution but unfortunately there’s no way to filter movies by aspect ratio - for example I want to find all 4:3 movies.
Workaround: use ExportTools
then open the resulting CSV file in a spreadsheet app
That way you can filter and sort for any minute technical aspect of your files.
