Hello Everyone,
I just bought a ultra widescreen with a 21:9 ratio. I was wondering if anyone knows how to search for movies using the ratio. I know you can search for 1080p or 720p files but is there a way to look for a ratio (ie 2.35 instead of 1.87).
IF there currently is no way to do this I was hoping we could make this possible. I very much want to make a playlist that is all my anamorphic movies.
Thanks,
Timmeh
There is no search field for this directly in Plex; however, you could add ExportTools (formerly Plex2csv) as a plugin to your PMS. This plugin exports the contents of your library to a spreadsheet. One of the export fields is aspect ratio, and you could easily sort the spreadsheet and create a playlist from that.
Only way I know of is either datamining the DB or exporting it then going back and manually tagging them
If on linux I’d write up a mediainfo script that would parse and dump movies with that AR you want then tag them in plex
Use that tag as your playlist
Thanks for your help. Does the export tools app work on mac?
Yes, I am in an Apple ecosystem and use the tool.
sorry to bother you again OmegaRed but when i downloaded the tool there was no install file. and when i opened it it just opened terminal with a blank screen. how does this tool work?
It’s a plug-in, not a standalone application. You need to place the .bundle file that you downloaded into the plug-ins folder for PMS. On a Mac, use the Go to Folder command (CMD+Shift+G), navigate to ~/Library/Application Support/Plex Media Server/Plug-ins and drop the bundle there. Restart your PMS. After that, you will find the plug-in listed under ‘Channels’ on PlexWeb. I recommend taking a moment to read the ExportTools wiki for tips on configuring the output.
Omega thanks for all the help you have been super awesome.
Might be easier dropping this in there
Then you can install/update the exporter easily and also have a bunch of nifty other tools
